Go to Post I think FIRST is probably close to the farthest you can get from 'gangsta', outscored only by the math team. - Tom Bottiglieri [more]
Unread 27-01-2013, 12:35
Jorge Ayala's Avatar
Jorge Ayala Jorge Ayala is offline
FRC #3478 (LamBot)
Rookie Year: 2010
Jorge Ayala is a splendid one to beholdJorge Ayala is a splendid one to beholdJorge Ayala is a splendid one to beholdJorge Ayala is a splendid one to beholdJorge Ayala is a splendid one to beholdJorge Ayala is a splendid one to beholdJorge Ayala is a splendid one to behold
Re: Shooting issues
Our team is getting some awesome shooting distance with just one motor, our shooter design in some way looks like yours. We had some issues regarding the shooting distances so we decided to use the CIM motor without any gears. And we also lifted the tire a little so that contact with the frisbee is made from under the tire (if you want to do this make sure it makes a decent compression). Another way to improve accuracy and shooting distance is eliminating vibration, we are still trying to figure out how to do that, we have already eliminate it to some extent and it has resulted in more accuracy, but we still have some vibration to get rid of.
This is a small (very small) video of our shooter.
Hope the advice helps you.
Website
Facebook
Twitter
Victory goes beyond winning.
Unread 27-01-2013, 13:05
dchartley dchartley is offline
FRC #3684
dchartley will become famous soon enough
Re: Shooting issues
If you find the direct drive parts or out of stock at AndyMark, I bought a couple of extra ones and can FedEx them to you. Let me know. Email at dchartley@seattleschools.org.
The sheet metal you are using looks like it may flex a lot. Might try to stiffen up the lower contact surface to that it does not flex while shooting.
Doug
Unread 27-01-2013, 15:42
andrewthecow's Avatar
andrewthecow andrewthecow is offline
FRC #3753
andrewthecow is an unknown quantity at this point
Re: Shooting issues
Just to sum up the other advice from this thread and give a little more input, I'd say there are 5 main ways to improve the shooting:
1. Check your compression of the frisbee; too much or too little can vastly diminish the amount of momentum transferred to the disk from the CIMs.
2. Direct drive the wheels using the AndyMark 8mm hub or at least get the gearing near 1:1.
3. Make the surface inside the shooter and opposite the CIMs much rougher, so that energy is more efficiently transferred into making the disk shoot further. My team is using skateboard grip tape for this.
4. Make sure that bolt heads do NOT contact the disks as they exit the shooter.
5. Watch the CIMs as the disks shoot and make sure that the c-channel they're attached to isn't twisting. If it is, it's changing the amount of compression you're getting.
Good luck at competition!
Unread 30-01-2013, 11:26
GilaMonsterAlex's Avatar
GilaMonsterAlex GilaMonsterAlex is offline
Lead Team Mentor
FRC #3785 (Gila Monsters)
Rookie Year: 2011
GilaMonsterAlex is an unknown quantity at this point
Re: Shooting issues
First thing I would do is speed up the wheels. You need to find a way to make it so. Then I would check the compression, and contact.
2014 - AZ Regional Finalist
2013 - AZ Regional Finalist
2013 - AZ Gracious Professionalism Award
2011 - AZ Motorola Quality Award
Unread 08-02-2013, 01:17
runneals's Avatar
runneals runneals is offline
FTC Mentor - The Robot Corps 7491
FRC #3928 (Team Neutrino)
runneals has a spectacular aura aboutrunneals has a spectacular aura about
Re: Shooting issues
Since you guys are a rookie team, I'll give you a hint.... Mount the wheel directly on the CIM and add 'squish' on the sides to increase the friction. The greater the friction, the better they fly! We used Rough Top (blue stuff) when we were prototyping. I personally suggest you do not use rough top, as it tares up the frisbees pretty easily (field damage), but instead search AM & online for something similar that is 'squishy' Hope this helps your team out, and good luck!
David Runneals
FRC 3928 Team Neutrino 4-H: Mentor (2015 Off-Season - ?)
FTC North Super Regional Championship: Game Announcer (2015)
FTC 7491 The Robot Corps 4-H: Mentor (2013 - ?)
FRC 2167 Mentor (2014)
FRC 3928 Team Neutrino 4-H: Member, Co-Captain, & Media Coordinator (2013)
Unread 26-01-2013, 00:56
akash992391 akash992391 is offline
AKA: Akash
FRC #4684
Rookie Year: 2013
akash992391 is on a distinguished road
Re: Shooting issues
Ok we will do that thanxxx though
Unread 26-01-2013, 21:11
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
Rookie Year: 2011
cgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond repute
Re: Shooting issues
You can use gears if you have to, they just have to be the same size.
BadgerBOTS Robotics|@team1306|Facebook: BadgerBOTS
2016 FIRST Championship Tesla Division | 2016 Wisconsin Regional Engineering Inspiration Award
2015 FIRST Championship Carson Division | 2015 Wisconsin Regional Chairman's Award
2013 FIRST Championship Curie Division | 2013 Wisconsin Regional Chairman's Award
2012 FIRST Championship Archimedes Division | 2012 Wisconsin Regional Engineering Inspiration Award, Woodie Flowers Finalist Award (Lead Mentor Ben Senson)
Unread 26-01-2013, 00:35
billbo911's Avatar
billbo911 billbo911 is offline
I prefer you give a perfect effort.
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
billbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond repute
Re: Shooting issues
It looks like the issue is you are using gear reduction to slow the motor output down.
Many teams are directly driving those wheels with the motor, no gear in between. You will get lots of torque, but speed it what you need.
CalGames 2009 Autonomous Champion Award winner
Sacramento 2010 Creativity in Design winner, Sacramento 2010 Quarter finalist
2011 Sacramento Finalist, 2011 Madtown Engineering Inspiration Award.
2012 Sacramento Semi-Finals, 2012 Sacramento Innovation in Control Award, 2012 SVR Judges Award.
2012 CalGames Autonomous Challenge Award winner ($$$).
2014 2X Rockwell Automation: Innovation in Control Award (CVR and SAC). Curie Division Gracious Professionalism Award.
2014 Capital City Classic Winner AND Runner Up. Madtown Throwdown: Runner up.
2015 Innovation in Control Award, Sacramento.
2016 Chezy Champs Finalist, 2016 MTTD Finalist
Unread 01-02-2013, 12:00
rwkling1's Avatar
rwkling1 rwkling1 is offline
FRC #2977 (Sir Lancer Bots)
Team Role: Leadership
Rookie Year: 2011
rwkling1 has a spectacular aura aboutrwkling1 has a spectacular aura about
Re: Shooting issues
what you should try is to make the "fence" (the aluminum on the opposite side of the wheels that the frisbee rides on) closer to the wheels. We made a prototype of a very similar shooter and one thing that we noticed is that you have to compress the frisbee. In example, when you try to put the frisbee through it by hand, it should bend the frisbee. Also, add some grip tape on the aluminum opposite from the wheels, that will increase spin making the frisbee fly farther. Lastly, try adjusting the height of the wheels, to where what part of the wheel touches the frisbee (rounded, apex, etc.)
wish you the best
from team 2977
