Go to Post College was the best twenty years of my life. - Richard Wallace [more]
Unread 26-01-2013, 11:24
LOHS3868 LOHS3868 is offline
FRC #3868
LOHS3868 is an unknown quantity at this point
Require help programming a Z-Axis on a Logitech joystick
Our programming team wants to use the Z-axis on a Logitech joystick as the throttle for our shooter motor. Our problem is that we want the negative portion to be zero and the positive to represent full throttle. Sorry for not being clear - it's hard to convey what I mean over text. If you need any more details, feel free to ask.
Thanks
-3868
Unread 26-01-2013, 11:55
agartner01 agartner01 is offline
Captain + Control Sys & Design
FRC #4174
Rookie Year: 2012
agartner01 is an unknown quantity at this point
Re: Require help programming a Z-Axis on a Logitech joystick
Thanks
-3868
What language are you programming in? If the most positive value is 1 and the most negative value is -1, what I've done in the past is added 1 and divided by 2 (to the joystick value). Also, an exception needs to be put in place when is the value is -1 because -1+1=0/.5 results in potentially undefined behavior (at least in c++).
Unread 26-01-2013, 12:00
Teamcodeorange's Avatar
Teamcodeorange Teamcodeorange is offline
FRC #3476
Teamcodeorange has a brilliant futureTeamcodeorange has a brilliant futureTeamcodeorange has a brilliant futureTeamcodeorange has a brilliant futureTeamcodeorange has a brilliant futureTeamcodeorange has a brilliant futureTeamcodeorange has a brilliant futureTeamcodeorange has a brilliant futureTeamcodeorange has a brilliant futureTeamcodeorange has a brilliant futureTeamcodeorange has a brilliant future
If you are using Labview you could just add one, divide by 2 and if it goes the wrong way, multiply by -1.
Try Code Orange's electronics tutorials!
2015 - Tesla Division Champions
2015 - Inland Empire Engineering Inspiration Award
2015 - San Diego Regional Chairman's Award
2014 - San Diego Regional Chairman's Award
2013 - Newton Division Champions
2012 - San Diego Regional Winners
Unread 26-01-2013, 12:23
Ether's Avatar
Ether Ether is offline
systems engineer (retired)
Rookie Year: 1969
There are 2 things wrong with the last sentence above.
1) Dividing zero by something does not result in undefined behavior. Dividing something by zero does.
2) 0/.5 is not dividing by 2. It is dividing by 1/2, which is multiplying by 2.
