Go to Post but it was late and we were out of cardboard... - Nuttyman54 [more]
Unread 26-01-2013, 11:28
mlantry mlantry is offline
I'm back
AKA: Matthew Lantry
Rookie Year: 2011
mlantry has much to be proud ofmlantry has much to be proud ofmlantry has much to be proud ofmlantry has much to be proud ofmlantry has much to be proud ofmlantry has much to be proud ofmlantry has much to be proud ofmlantry has much to be proud ofmlantry has much to be proud of
What clutches are legal for FRC use?
I know a thread already exists about electro-magentic clutches http://www.chiefdelphi.com/forums/sh...d.php?t=110778 and I've asked the question what clutches are legal and where to buy them. I got a response about the dog clutch from AM but I think those are only used in the transmissions. What I was wondering was what clutches I could put onto a shaft and a second shaft, where only one shaft will turn until the clutch is engaged, and then both shafts will turn.
Matthew Lantry
Team 4475 2014-present
-College Mentor 2014-????
Team 1676- 2011-2014
-Mechanical 2011-2014, Subteam leader 2013-2014
-Robot Operator 2014
George G. White FLL mentor 2011-2014
“Both optimists and pessimists contribute to our society. The optimist invents the airplane and the pessimist the parachute.”
Unread 26-01-2013, 11:32
Re: What clutches are legal for FRC use?
A mechanical clutch is easily machinable to be used in a similar manner as shifter dog gears. You can create a larger dog and use a larger bore piston for desired effect. A couple teams did this in 2010 for kickers.
I'm assuming this is part of your hanger?
Unread 26-01-2013, 18:47
I'm back
AKA: Matthew Lantry
Rookie Year: 2011
your right on the hanger and we would like to purchase one if possible from a manufacture (as stated above).
Matthew Lantry
Unread 26-01-2013, 23:22
Paul T.'s Avatar
Paul T. Paul T. is offline
no team (Team WARP)
Rookie Year: 2012
Paul T. is on a distinguished road
i don't know of any ones that could do that on the same shaft (could be my inexperience showing) but i know you could use a second shaft and a dog gear to engage or disengage the 2nd shaft
ROOKIE Team 5400 WARP Mentor
Former FRC 1687 Highlander Robotics
Metal of Honor - Battle Cry 13 @ WPI
WPI districts Semifinalists-2014
Unread 27-01-2013, 13:59
nuttle nuttle is offline
AKA: Allen Nuttle
FRC #4080
nuttle has much to be proud ofnuttle has much to be proud ofnuttle has much to be proud ofnuttle has much to be proud ofnuttle has much to be proud ofnuttle has much to be proud ofnuttle has much to be proud ofnuttle has much to be proud of
Something like this might work: <http://www.wmberg.com/catalog/catpag...df/B05J002.pdf>.
