| Nothing in the KOP can prepare me for you. |
cRIO Assistance
We have already deployed a basic code onto the cRIO, but after tweaking and editing the previous code, we attempted to deploy the refined one. The cRIO detects the connection, the drive station works, but after a bit of research, the conclusion has been drawn that the cRIO is failing to over-write the old code with the new. Is there any way to fix this?
Thank you, Madeline |
Re: cRIO Assistance
If the deployment is failing with a message saying that it is waiting for the controller, try shutting down the dashboard before deploying. There are a few other threads about this, and a patch is expected to be released relatively soon.
Greg McKaskle |
Re: cRIO Assistance
What exactly are you referring to as the dashboard?
Re: cRIO Assistance
The dashboard is the Dashboard.exe that generally opens above the driver station. If you close the driver station, that will often close the dashboard or will at least show the close button on it.
Greg McKaskle |
Re: cRIO Assistance
Also, the link light on the cRIO is a rapidly blinking yellow, even when there is nothing plugged into it. That seems to be an issue as well.
Re: cRIO Assistance
Also, it has now been noted that the USER1 light on the cRIO is not lighting up green when it should be.
