Go to Post ... you know you are a nerd when you want safety glasses for your birthday! :P - Ashley Christine [more]
Unread 26-01-2013, 13:52
April McShorty April McShorty is offline
Most Senior Member (Grandmama)
AKA: April Tobergte
FRC #0240 (Tempest)
Rookie Year: 2012
April McShorty is an unknown quantity at this point
What's the best shooting angle for a frisbee?
Please help! I've been looking up angles up while the build team's been testing, but we can't get the just right angle. It would be amazing if someone tell us.
Unread 26-01-2013, 13:56
nikeairmancurry's Avatar
nikeairmancurry nikeairmancurry is offline
FF - TeamSuperPowerMatic
AKA: Nicholas
FRC #0313
nikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond repute
Re: What's the best shooting angle for a frisbee?
Well, it partly depends on the distance your shooting and the rpm of your shooting wheel.
Team Member- 326 2006-2009
Team Mentor- 326 2010-2013
Team Mentor- 313/5220 2014-??
Unread 26-01-2013, 13:59
nuggetsyl's Avatar
nuggetsyl nuggetsyl is offline
FRC #0025
Team Role: Coach
nuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond repute
68.9348532 degrees when shooting from 10 feet 8 3/4 inches give or take a 1000th of an inch. God I hope the field is built to spec.
00,12Championship winner
03,06,08 Championship finalist
02A,03C,06N,08C,11N,12G Division winner
00,03,06,07,08,10,12 NJ / MAR winner
11 VCU winner
06,10 Las Vegas winner
12 MAR Mt Olive
red is for team 348
Unread 26-01-2013, 14:09
ENeyman's Avatar
ENeyman ENeyman is offline
AKA: Emmett Neyman
FRC #3929 (Atomic Dragons)
Team Role: Leadership
Rookie Year: 2011
ENeyman has a brilliant futureENeyman has a brilliant futureENeyman has a brilliant futureENeyman has a brilliant futureENeyman has a brilliant futureENeyman has a brilliant futureENeyman has a brilliant futureENeyman has a brilliant futureENeyman has a brilliant futureENeyman has a brilliant futureENeyman has a brilliant future
We got the best distance at 20-25 degrees.
Mid-Atlantic Regional Championships (2012)- Rookie All-Star Award
World Championships (2012)- Rookie Inspiration Award
Chestnut Hill District, Mt. Olive District (2013)- Entrepreneurship Award
Lenape District (2014)- Winner
frc3929.org
Unread 26-01-2013, 14:48
Tuba4 Tuba4 is offline
AKA: Tom Albert
FRC #0063 (The Red Barons)
Tuba4 has a brilliant futureTuba4 has a brilliant futureTuba4 has a brilliant futureTuba4 has a brilliant futureTuba4 has a brilliant futureTuba4 has a brilliant futureTuba4 has a brilliant futureTuba4 has a brilliant futureTuba4 has a brilliant futureTuba4 has a brilliant futureTuba4 has a brilliant future
With a normal ballistic type projectile, the longest range at a given muzzle velocity would be at 45 degrees. But a frisbee is anything but ballistic. After a little trial and error, we also found that a 20 to 25 degree angle worked best.
Unread 26-01-2013, 17:45
DonRotolo's Avatar
Back to humble
FRC #0832
The correct answer is that you need to try each angle and see for yourself. That means that you should take about 10 shots or more from each angle starting at 0° and going to about 45°. Record how each frisbee flew on a piece of paper and then use that data to decide for yourself, given your exact shooter configuration, what is best.
This is called the experimental method. It is a major part of science and engineering and is good to learn. Good luck.
