Go to Post I didn't think it was possible for Dave to be any more cryptic. I was wrong. - IMDWalrus [more]
Unread 26-01-2013, 20:18
CrazyRussian96's Avatar
CrazyRussian96 CrazyRussian96 is offline
pneumatic/electrical derp
AKA: Dennis Chertkovsky
FRC #3492 (Putnam Area Robotics Team P.A.R.T.ƨ)
Team Role: Electrical
Rookie Year: 2011
CrazyRussian96 is an unknown quantity at this point
Question Connecting an external air compressor to robot's pneumatic system
To save weight, my team decided (okay, mentors sort-of forced this upon us) to mount our air compressor on the cart instead of the robot, charging up its compressed air tanks between matches. I have read the rules regarding the pneumatic system (I know that the external compressor must be powered and controlled by the robot), yet I am still confused about one detail: how exactly do I connect the compressor to the robot's pneumatic system? We must be able to quickly connect and disconnect the compressor without leaking any pressure. My current idea is to simply screw a pneumatic tube fitting into the free end of the robot's manual pressure relief valve, and use it to connect to a tube leading to the external compressor (which will have its own manual pressure relief valve as mandated by the rules). Is this legal? Another idea I had was to use a check valve of some sort that wouldn't have to be manually opened and closed with each filling. Is there any legal pneumatic component resembling a check valve that can be used for this purpose? I know the flow rate regulators used on pneumatic cylinders function somewhat like check valves, but can they be safely and legally used as check valves for this purpose?
