Thread Tools |
Rating:
Display Modes |
Re: Welding Urethane Belts
We used belts for picking up the balls last season and using them again this year. The easiest way we find it to use a heat gun (WEAR GLOVES!!) and heat up the two ends and press together. It usually works pretty well.
We have heated a strip of sheet metal (held with Vice Grips) with a propane or MAPP gas torch and pressed the ends of the belt onto each side of the sheet metal and then pulled the sheet metal away letting the ends touch and fuse together. Took several tries to get the heat timing right but worked well.
