How can I program the Camera Axis point to appear in the Drive station?
Hiii guys
![]() How can I program the Camera Axis point to appear in the Drive station? I really want to know !! so fast )please help me if you can! |
Re: How can I program the Camera Axis point to appear in the Drive station?
The Driver Station is the bottom third of the screen and cannot be modified.
The Dashboard is the top two thirds of the screen and can be anything you want. By default, it is a built LabVIEW application that will open a session to a camera at address 10.te.am.11. No programming needed. Steps are to configure the camera using the camera setup tool or manually. Connect it to the DLink switch and provide it power. If you have switched to the Java SmartDashboard, the steps are similar, but ensure that the anonymous viewing is enabled as well. Greg McKaskle |
Okay thanx a lot darling
![]() It worked the camera image appeared in the Drive Station (DashBoard FRC) |
