Go to Post "Check out those sexy transmissions!" - Eric W. Jones [more]
Unread 01-27-2013, 04:53 PM
pigpenguin's Avatar
Happy Birthday! pigpenguin pigpenguin is offline
Registered insane
AKA: Ethan Rooke
FRC #1160 (Titanium Robotics)
pigpenguin is an unknown quantity at this point
Servo problems
First of all I am not completly sure that this is the right forum to be posting this in. The problem spans a couple of areas and I was not sure which one to post it in.
Any way basically our programming team is trying to make a servo move to no avail. The code in question is right here: Github. We have confirmed that the input is making it to the output manager and that the manager is running the servo.set() method. Additionally when we ask the servo for its position it tells us it moved (I am not really sure if when you ask if you are asking the hardware or checking your last set position) on the hardware side of things we have tried multiple ports, servos, sidecars, and pretty much every way we could come up with to make the servo move to no avail.
Does any one have any ideas on what is up?
"Insanity isn't a plea its a way of life and here we are all one card short"
Unread 01-27-2013, 05:20 PM
Ether's Avatar
Ether Ether is offline
systems engineer (retired)
Rookie Year: 1969
Re: Servo problems
The PWM going to the servo is one-way communication. There is no provision for the servo to tell you that is has moved.
What are you trying to move with the servo? You're not trying to lift something heavy, are you?
Unread 01-27-2013, 05:36 PM
pigpenguin's Avatar
Registered insane
AKA: Ethan Rooke
Re: Servo problems
That makes sense
No, right now there is nothing on the servo except for the plastic hub that came with it
Unread 01-27-2013, 06:24 PM
Ether's Avatar
Rookie Year: 1969
Re: Servo problems
Are you giving the servo power? You need to place the jumper to provide power to the servo or it will not move.
Unread 01-27-2013, 06:40 PM
pigpenguin's Avatar
Registered insane
AKA: Ethan Rooke
Re: Servo problems
yeah we have placed a jumper on the two pins next to the pwm out
Unread 01-27-2013, 07:01 PM
Ether's Avatar
Rookie Year: 1969
Re: Servo problems
Apologies for asking the obvious question, but do you have a center wire in your PWM cable and 3 pins at each end?
Unread 01-27-2013, 07:30 PM
pigpenguin's Avatar
Registered insane
AKA: Ethan Rooke
Re: Servo problems
yes
Unread 01-27-2013, 07:46 PM
Re: Servo problems
Have you tried using test mode to identify whether it is a code or electrical issue?
Greg McKaskle
Unread 01-27-2013, 10:43 PM
AsianRookie AsianRookie is offline
AKA: Steven/Tim
FRC #0321 (Robolancers)
Rookie Year: 2007
AsianRookie is an unknown quantity at this point
Re: Servo problems
servo.set(value), is value between 0 and 1?
Unread 01-27-2013, 11:07 PM
pigpenguin's Avatar
Registered insane
AKA: Ethan Rooke
Re: Servo problems
Greg McKaskle
No, to be honest I have never heard of test mode. I will try that tomorrow when I get my hands on the bot again.
Yes, the way we have it set up right now we have a button, when the button is not pressed the servo is set to 0.0 and when it is pressed the servo gets set to 1.0
Unread 02-01-2013, 02:15 AM
pigpenguin's Avatar
Registered insane
AKA: Ethan Rooke
Re: Servo problems
For any one curious it was a bad jumper... which was the one thing no one thought to check.
