Go to Post The pie is as large as you make it. - boomergeek [more]
Unread 27-01-2013, 17:56
ksafin's Avatar
ksafin ksafin is offline
AKA: Kirill Safin
FRC #3992 (Eagles Robotics Xperience)
Team Role: Leadership
Rookie Year: 2012
ksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant future
Using Anderson PowerPoles
Our team decided to get Anderson PowerPoles this year to improve on our electric wiring and organization.
I wanted to get the opinion of other teams who have used APP's in the past about where best and how best to utilize them, IE:
Crimping to end of motor wires?
Crimping straight to motor controllers?
Crimping to a small wire right out of PDB outlets?
Just a few ideas; I'd like to hear how you use them and maybe pictures if you can.
FTC Teams 5257, 6568 & FRC Team 3992
2014 FTC WORLD CHAMPIONS
14 Trophies in 3 Years
Unread 27-01-2013, 18:00
Steven Donow Steven Donow is offline
AKA: Scooby
Steven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond repute
Re: Using Anderson PowerPoles
We plan on using them this year, and odds are, we're probably crimping them right to the end of the motor wires. IMO, the two most likely things to fail (that APPs could be used with) would be speed controllers and motors. If a speed controller fails, all you need to do is to unscrew terminals, remove the controller, and replace it. If a motor fails, no matter what you have to take the motors out, so it's easier to just unplug the APPs then having to replace the wire/tape it back onto the motor/solder it back on to the motor.
Unread 27-01-2013, 18:12
androb4's Avatar
androb4 androb4 is offline
..is trying to take this year off.
AKA: Andrew A.
androb4 is a splendid one to beholdandrob4 is a splendid one to beholdandrob4 is a splendid one to beholdandrob4 is a splendid one to beholdandrob4 is a splendid one to beholdandrob4 is a splendid one to beholdandrob4 is a splendid one to behold
We have not used these yet but plan on doing so soon. I think we will be crimping them on every (current legal) motor in our bins, and make adapters for motors with connecters like FPs and just use the APP as our standard connector; making it easy to mix and match different motors easily.
FRC 441 Mentor 2012-2015
FRC 441 Alumni 2009-2012
FTC 4673 Alumni 2011-2012
FRC 1484 Alumni 2006-2008
Unread 27-01-2013, 19:38
Jon Stratis's Avatar
Electrical/Programming Mentor
FRC #2177 (The Robettes)
I've seen teams use them on the ends of motors... It can be pretty useful if you have to swap out a motor between matches.
We use them as an interface between any removable component. For example, the entire electrical board can be unplugged from the robot pretty quickly. Last year, our shooter was removable, so we had additional plugs between the shooter and the rest of the robot.
2007 - Present: Mentor, 2177 The Robettes
LRI: North Star 2012-2016; Lake Superior 2013-2014; MN State Tournament 2013-2014, 2016; Galileo 2016; Iowa 2017
2015: North Star Regional Volunteer of the Year
2016: Lake Superior WFFA
Unread 27-01-2013, 20:12
protoserge's Avatar
protoserge protoserge is offline
CAD, machining, circuits, fun!
AKA: Some call me... Tim?
FRC #0365 (MOE) & former 836 Mentor)
protoserge has a reputation beyond reputeprotoserge has a reputation beyond reputeprotoserge has a reputation beyond reputeprotoserge has a reputation beyond reputeprotoserge has a reputation beyond reputeprotoserge has a reputation beyond reputeprotoserge has a reputation beyond reputeprotoserge has a reputation beyond reputeprotoserge has a reputation beyond reputeprotoserge has a reputation beyond reputeprotoserge has a reputation beyond repute
Double check the amperage rating if attaching to your CIMs before buying/crimping.
They are very helpful, as others have noted. You can secure the APP connecting the two halves of the circuit together with a zip tie if you are afraid they might come undone (highly unlikely).
Unread 27-01-2013, 20:25
Dale's Avatar
Dale Dale is offline
Head Coach & Mentor
AKA: Dale Yocum
FRC #1540 (Flaming Chickens)
Team Role: Coach
Dale has much to be proud ofDale has much to be proud ofDale has much to be proud ofDale has much to be proud ofDale has much to be proud ofDale has much to be proud ofDale has much to be proud ofDale has much to be proud ofDale has much to be proud of
We tend to also use them so that the control systems folks can continue wiring things without being in the way of the mechanical people. You can wire your whole control board, put connectors on the end of the motors, and them snap the whole thing together at the end jiffy quick.
On the flip side of the coin the connectors are a major source of failure if not done properly. Make sure you give each wire a good tug after it's assembled. If the wire comes out ... well it shouldn't have. We've had more failures due to improperly crimped or assembled connectors than we have ANY other component in the electrical system.
Be sure to get the proper crimp tool for the connectors.
2016 PNW Championship Chairman's; 2016 Winner Oregon City District, 2015 PNW Championship Chairman's; 2015 PNW District Engineering Inspiration; 2015 PNW District Finalist; 2014 PNW Championship Chairman's; 2014 Championship Innovation in Controls; 2013 Chairman's (Oregon); 2013 Finalist (OKC); 2012 Winner (OKC); 2012 Chairman's (OKC); 2012 Woody Flowers (Oregon); 2011 Volunteer of the Year (Oregon); 2011 Finalist & Captain (San Diego); 2011 Innovation in Control (San Diego); 2010 & 2007 Chairman's (Oregon); 2010 Regional Champions (Colorado); 2010 Innovation in Control (Colorado); 2009 & 2008 Engineering Inspiration (Oregon); 2008 Regional Champions (Oregon); 2007 Regional Finalist (Oregon); 2005 Rookie Inspiration (PNW)
Unread 27-01-2013, 20:26
iambujo iambujo is offline
Mentor
FRC #2729 (Storm)
iambujo is a name known to alliambujo is a name known to alliambujo is a name known to alliambujo is a name known to alliambujo is a name known to alliambujo is a name known to all
We use them for all motor connections. This will be our second or third year using them. They make a huge difference for reliability, parts replacement and cleanliness. For 2729, they are a must.
Unread 27-01-2013, 20:43
Mr. Lim Mr. Lim is offline
AKA: Mr. Lim
Rookie Year: 1998
Mr. Lim has a reputation beyond reputeMr. Lim has a reputation beyond reputeMr. Lim has a reputation beyond reputeMr. Lim has a reputation beyond reputeMr. Lim has a reputation beyond reputeMr. Lim has a reputation beyond reputeMr. Lim has a reputation beyond reputeMr. Lim has a reputation beyond reputeMr. Lim has a reputation beyond reputeMr. Lim has a reputation beyond reputeMr. Lim has a reputation beyond repute
We crimp APPs to every motor on our robot. We have a standard pigtail length, and zip tie the APPs + pigtails in such a way to provide strain relief.
This makes swapping out failed motors very straightforward, and ensures all our spare motors will always fit, without having to rewire anything.
We do the same with our sensors by putting PWM connectors on a standard pigtail length.
At the speed controller, we do not use APPs. Instead we use standard crimp quick-disconnects in combination with these:
http://www.digikey.ca/product-search...yWords=42095-1
They make swapping out failed speed controllers a breeze - but we also usually mount one spare speed controller of each type on the board. These disconnects also make swapping a motor over to a spare motor controller very easy. We keep a few quick disconnect extension cables handy - male on one end, female on the other. In a pinch we can move a motor from a failed motor controller to the spare, and make a quick code change.
After doing this for a few years, it also makes prototyping go smoother, because all your motors and sensors a plug and play!
In life, what you give, you keep. What you fail to give, you lose forever...
Unread 27-01-2013, 20:48
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
I should have added that for extra added protection we follow the crimp with solder. Yeah it is sort of like suspenders and a belt.
Al
WB9UVJ
www.wildstang.org
________________________
Unread 27-01-2013, 20:53
ksafin's Avatar
AKA: Kirill Safin
Rookie Year: 2012
Do any of you have pictures of your APP setups and uses?
Unread 27-01-2013, 21:10
AKA: Mr. Lim
Rookie Year: 1998
http://www.chiefdelphi.com/media/img...e46e104b_l.jpg
But you've seen this already...
APPs are crimped and ziptied to 6 of 7 CIMs pictured above.
Unread 27-01-2013, 21:20
AllenGregoryIV's Avatar
AllenGregoryIV AllenGregoryIV is offline
Engineering Coach
AKA: Allen "JAG" Gregory
FRC #3847 (Spectrum)
Team Role: Coach
AllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond repute
Send a message via AIM to AllenGregoryIV
We used them everywhere last year. There is a picture of our speed controller board in this blog post.
We're going to continue using them for motors but will be using the method that Mr. Lim and Al have suggested for speedcontrollers and other wiring. Standard pigtails and strain reliefs are very important for the motor wires. Also make some Anderson extension cables and also a Large (SB50 Battery) Anderson to Powerpole converter cable. We use the converter for quick motor tests (safer than alligator clips) and also for hooking up batteries to our new CBA (Battery analyzer)
Team 647 | Cyber Wolf Corps | Alumni | 2003-2006 | Shoemaker HS
Team 2587 | DiscoBots | Mentor | 2008-2011 | Rice University / Houston Food Bank
Team 3847 | Spectrum | Coach | 2012-20... | St Agnes Academy
LRI | Alamo Regional | 2014-20...
"Competition has been shown to be useful up to a certain point and no further, but cooperation, which is the thing we must strive for today, begins where competition leaves off." - Franklin D. Roosevelt
Unread 27-01-2013, 21:51
We do this as well. In fact, we solder every connector on the robot, after crimping. It's just too easy to get a bad crimp and thus a loose wire.
Unread 28-01-2013, 16:54
JDL JDL is offline
Systems Integrator
FRC #0498
JDL is just really niceJDL is just really niceJDL is just really niceJDL is just really nice
I personally hate when people go all quick connect happy. Motors make sense, so do things on removable parts of the robot, like an arm with motor(s), switches, sensors, that can be easily removed for repairs, but every circuit seems like overkill.
  #15   Spotlight this post!
Unread 14-02-2013, 19:53
djdaugherty djdaugherty is offline
Mrs. D.
FRC #2053 (TigerTronics)
Team Role: Teacher
djdaugherty is on a distinguished road
We started using Anderson PowerPole connectors last year and we love them. We purchased the crimp tool from West Mountain Radio. Does anyone else have the problem of the crimped end getting stuck in the crimper? We need to pry each one out. Any suggestions?
