Go to Post The only people who are dumb or ignorant in this world are the ones who don't stop and ask why. - T967 [more]
Unread 27-01-2013, 21:44
jhellr13 jhellr13 is offline
FRC #4272
Rookie Year: 2010
jhellr13 is an unknown quantity at this point
Moving autonomous programs to teleop
I am looking for some help with automating some tasks in teleop by using code from autonomous.
For example, lets say I have an autonomous mode where the first while loop is to drive straight using encoders for a certain distance, then move to another loop where the robot turns in a circle using the encoders, and then moves to a while loop where the motors are stopped.
Now lets say that I want to use that code during teleop if i press a button. Do I just copy the code from autonomous and place it in a case structure attached to the button in teleop? Does it have to go in periodic tasks instead? Does each while loop have to be in a flat sequence as well?
Help please? Thanks
Unread 27-01-2013, 21:50
Re: Moving autonomous programs to teleop
TeleOp is designed to return to the scheduler and be called again every 20ms. If you put code there that takes longer than 20ms to run, it will cause the robot to miss joystick values. I'd recommend putting the code into Periodic tasks and using a global to cause it to start and stop when appropriate, auto or teleop.
Greg McKaskle
Unread 27-01-2013, 21:54
FRC #4272
Rookie Year: 2010
Greg McKaskle
Thanks! I'll try that tomorrow. Could you elaborate on what you mean by using a global? Do you mean make a global boolean variable in teleop to check if the button is pressed, then read the global in periodic tasks and perform the action?
Unread 28-01-2013, 05:54
That would work. Or make a global that is set in teleOp based on button state and other logic and Periodic reads it to determine what to do next.
Greg McKaskle
