Go to Post So now that the Championship is over, how long 'till next kick off? ;) :p - Michelle Celio [more]
Unread 28-01-2013, 01:37
AllenGregoryIV's Avatar
AllenGregoryIV AllenGregoryIV is offline
Engineering Coach
AKA: Allen "JAG" Gregory
FRC #3847 (Spectrum)
Team Role: Coach
AllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond repute
Send a message via AIM to AllenGregoryIV
pic: MiniCIM Versaplanetary
Unread 28-01-2013, 01:39
DampRobot's Avatar
DampRobot DampRobot is offline
Physics Major
AKA: Roger Romani
FRC #0100 (The Wildhats) and FRC#971 (Spartan Robotics)
Rookie Year: 2010
DampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond repute
Re: pic: MiniCIM Versaplanetary
So, essentially, the Mini-CIM mounts to the holes that hold the gearbox together? Also, how do you mount the CIM shaft to the pinion? I didn't know that there was a 8mm pinion available for those gearboxes.
The mind is not a vessel to be filled, but a fire to be lighted.
-Plutarch
Unread 28-01-2013, 01:41
Engineering Coach
Team Role: Coach
Check out the blog post for the full instructions. You don't use the holes that hold the gearbox together you use the other two holes. There isn't a pinion at all, the gearbox accepts an 8mm shaft and key.
Team 647 | Cyber Wolf Corps | Alumni | 2003-2006 | Shoemaker HS
Team 2587 | DiscoBots | Mentor | 2008-2011 | Rice University / Houston Food Bank
Team 3847 | Spectrum | Coach | 2012-20... | St Agnes Academy
LRI | Alamo Regional | 2014-20...
"Competition has been shown to be useful up to a certain point and no further, but cooperation, which is the thing we must strive for today, begins where competition leaves off." - Franklin D. Roosevelt
Unread 28-01-2013, 09:38
Kellen Hill's Avatar
Kellen Hill Kellen Hill is offline
Strategist
AKA: The user formerly known as 'hill'
FRC #1746 (OTTO)
Kellen Hill has a reputation beyond reputeKellen Hill has a reputation beyond reputeKellen Hill has a reputation beyond reputeKellen Hill has a reputation beyond reputeKellen Hill has a reputation beyond reputeKellen Hill has a reputation beyond reputeKellen Hill has a reputation beyond reputeKellen Hill has a reputation beyond reputeKellen Hill has a reputation beyond reputeKellen Hill has a reputation beyond reputeKellen Hill has a reputation beyond repute
Are you planning to use these on your drivetrain?
If so, what reduction are you using in the gearbox?
1625 Winnovation Member: 2005-07
1625 College Mentor: 2007-11
525 Swartdogs Mentor: 2011-12
1746 OTTO Lead Mentor: 2013-Present
Unread 28-01-2013, 11:13
Chris is me's Avatar
AKA: Pinecone
I really wish you had posted this two weeks ago. At one point I designed a mechanism that fed a mini-CIM through a VP and we had to redesign everything once we realized it wasn't a stock fit. I guess we should have been more creative.
Novel design nonetheless!
Unread 28-01-2013, 11:36
Engineering Coach
Team Role: Coach
No, we wouldn't risk that. We have a use for one right now and it will probably see the actual robot but it won't be on the drive train. With 6 regular CIMS allowed there is no need (unless you have a serious power need for a climbing device) to use anything but large CIMs on your drive train.
I wish we had known as well, we didn't find it until JVN hinted at the possibility. I still can't believe VEX designed all of these features into the gearboxes and never talked about it.
Unread 28-01-2013, 11:46
Strategist
FRC #1746 (OTTO)
I was thinking of putting the large CIM into the planetary. Should mount the same as a mini CIM unless I'm mistaken.
We currently have a couple old Banebot planetaries and are looking to switch them out.
Unread 28-01-2013, 11:52
Engineering Coach
Team Role: Coach
Oh, yes the input would be the same but again this current setup has very little keyway profile so for heavy torque applications it might not be the best design. (This is just from FRC experience I'm not a Mechanical Engineer.)
We are using the VEXpro single speed gearboxes but I would think the VPs could work in place of the large BB gearboxes. Check the torque ratings table on the VEXpro website for guidance though non of those are for this setup as it isn't officially recommended by VEX.
The single speed gearboxes we are using are 5.33:1 so a 5:1 VP would be a suitable replacement.
Unread 28-01-2013, 15:02
ken.3038 ken.3038 is offline
FRC #3038 (I.C.E.)
ken.3038 is an unknown quantity at this point
Our team is going with a single wheel (8" pneumatic) with a curve. The first attempt was a CIM direct to a hub mounted on the wheel but failed. The hub egg shaped from the CIM shaft. Next we tried a belt driven shaft mounted with bearings but there is to much vibration. We have ordered 2 Versaplanetary gearboxes which one will be changed to 1:1. Mounted to a AndyMark 1/2" hex hub. The idea came from your thread with your small shooter. I shouldn't have cut the shaft with a 1:1 correct?
Unread 28-01-2013, 15:41
Engineering Coach
Team Role: Coach
If you are mounting a CIM to the VP you will have to cut the shaft no matter what gear ratio. The shaft can't go all the way through the input stage, unless you did some really interesting modifications. You could use standoffs and cut the shaft less than we did.
Unread 28-01-2013, 16:29
billbo911's Avatar
billbo911 billbo911 is offline
I prefer you give a perfect effort.
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
billbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond repute
Originally Posted by AllenGregoryIV View Post
...You could use standoffs and cut the shaft less than we did.
I believe a solid machined block might give a more secure interface than standoffs.
As you suggested, this would give both the Mini CIM and CIM the ability to interface to the VP without modification.
Are you catching this John? It would make an already great transmission even better.
CalGames 2009 Autonomous Champion Award winner
Sacramento 2010 Creativity in Design winner, Sacramento 2010 Quarter finalist
2011 Sacramento Finalist, 2011 Madtown Engineering Inspiration Award.
2012 Sacramento Semi-Finals, 2012 Sacramento Innovation in Control Award, 2012 SVR Judges Award.
2012 CalGames Autonomous Challenge Award winner ($$$).
2014 2X Rockwell Automation: Innovation in Control Award (CVR and SAC). Curie Division Gracious Professionalism Award.
2014 Capital City Classic Winner AND Runner Up. Madtown Throwdown: Runner up.
2015 Innovation in Control Award, Sacramento.
2016 Chezy Champs Finalist, 2016 MTTD Finalist
Unread 28-01-2013, 17:47
Engineering Coach
Team Role: Coach
I agree with the secure interface idea. However I'm not sure you can do it without modification because the keyway on the 8mm shaft of the CIM and MiniCIM doesn't extend to the end of the shaft.
Unread 04-02-2014, 01:09
DampRobot's Avatar
Physics Major
AKA: Roger Romani
Rookie Year: 2010
I've seen VersaPlaetaries configured like this on Build Blitz, but I couldn't find any more info on how to use the VersaPlanetaries in this way with the new version. I assume others have done this successfully since then. How did you do it with the new version? Specifically, what plates did you use, did you cut off the CIM shaft, and did you still have to use 8-32 screws in place of the 10-32s in the CIM?
-Plutarch
Unread 04-02-2014, 01:12
R.C.'s Avatar
R.C. R.C. is offline
2017... Oooh Kill em, Swerve!
AKA: Owner, WestCoast Products
FRC #1323 (MadTown Robotics)
R.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond repute
We are using MiniCIMs in Vp's. What we are doing is cutting the shaft. Drilling out the CIM mounting holes to #10 (the input housing only) and then turning down socket bolt heads to fit nicely, works well.
R.C.
Owner, WestCoast Products || Twitter
MadTown Robotics Team 1323
  #15   Spotlight this post!
Unread 04-02-2014, 01:15
DampRobot's Avatar
Physics Major
AKA: Roger Romani
Rookie Year: 2010
Do you use any of the plastic/aluminuim plates or no?
-Plutarch
