Go to Post It's very confusing to other people on the message boards when you make things up that are incorrect and assert them as fact. Please don't do this. - Dave Flowerday [more]
Unread 28-01-2013, 11:42
rsisk's Avatar
rsisk rsisk is offline
The GURU Channel
AKA: Richard Sisk
FRC #2493 (Robokong)
Rookie Year: 2007
Power Distribution Board visibility for inspection
Our team is using a long version of the Kit Bot drive train and we mounted our Power Distribution Board under the motors. We are now concerned about visibility during inspections as covered by the rule...
R42
The PD Board and all circuit breakers must be easily visible for Inspection.
We think it is visible, you can see the wires connected to the board, the breakers on the board, and the connections for the Radio power supply and cRIO. It does take some effort, looking around the motors and removing the battery, but we think the board is visible, the part that worries me is the word "easily".
Reconfiguring the electronics board at this point would be tough.
Looking for opinions of what we might face during inspection.
The views expressed are mine and should not be construed to represent the views of anyone else.
Unread 28-01-2013, 11:48
ehochstein's Avatar
ehochstein ehochstein is offline
Coach, Volunteer & Mentor
AKA: Evan Hochstein
FTC #5943 (ESGM)
Team Role: Coach
Rookie Year: 2007
ehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant future
Re: Power Distribution Board visibility for inspection
Tie the wires together, label and shorten them as much as possible. The longer an inspector spends with your robot the more things they will find wrong.
I believe inspectors have to make sure the correct snap-action breaker is in the correct slot. From the perspective of the picture (I would call this the "easy perspective") you cannot do that therefore you would fail inspection until the breakers were visible. Last time I was an inspector at a regional was 2011, so if I am wrong and something has changed please let me know.
Also if any of your breakers fail during a match how do you expect to replace them? Place your PD on top of the hex tubes instead.
Minnesota FIRST Senior Mentor | 2013-?
Stratasys Applications Engineering Technician | 2016-?
2009 Regional Win – 2470 @ 10k Lakes (Thanks 2826 and 1714)
2013 WFFA Recipient – 2470 @ 10K Lakes
2016 Ri3D: 'Snow Problem Reveal
The opinions expressed above are the personal opinions of the author and do not necessarily represent the views and opinions of any organization the author is affiliated with.
Unread 28-01-2013, 12:08
EricVanWyk EricVanWyk is offline
Rookie Year: 2000
EricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond repute
Send a message via AIM to EricVanWyk
This is a good thing! The inspectors' job is two fold:
1) Ensure finger count and blood volume constancy.
2) Maximize the time you spend working on the field.
I would argue that R42 should read:
The PD Board and all circuit breakers must be easily visible so that issues with your wiring can be identified and fixed quickly, during inspection or otherwise, because you really really want to spend as much time as possible playing and not fixing.
... but then the rules would reach 200 pages.
So, regardless of whether it would pass their inspection - would it pass yours?
Unread 28-01-2013, 12:21
vhcook's Avatar
vhcook vhcook is online now
Reader of Things
AKA: Victoria
FRC #1939 (Kuh-nig-its)
vhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond repute
Looking at this picture, inspectors would have to suffer quite a bit to see the breaker ratings and what wire size goes into which wago. It's also going to be a giant pain to work on if it breaks. I'm assuming there's going to be more robot above this part, which is only going to make this harder to deal with.
One other thing to consider is that gearboxes innately tend to leak tiny metal shavings. With this design, gravity is not your friend.
Unread 28-01-2013, 12:28
darkember darkember is offline
AKA: Billy
FRC #0375 (Robotic Plague)
Rookie Year: 2007
darkember is a glorious beacon of lightdarkember is a glorious beacon of lightdarkember is a glorious beacon of lightdarkember is a glorious beacon of lightdarkember is a glorious beacon of light
It seems that you would have a pretty hard time adding/adjusting anything in your electronics with that setup. If you guys have the space, mount the PDB directly above the motors while using some plastic on top of the 2 braces you guys have between the motors. Then send all the wires under the board using the braces to channel and hide any spare wire you guys might have. If that isnt an option then just try to make the wires neater by sending the wires under the current mounts that you have and along the interior so that the inspectors have a clearer view of your electronics. Hope this help.
Unread 28-01-2013, 12:36
MrForbes's Avatar
MrForbes MrForbes is online now
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Richard, I don't know what you'll face during inspection, but I would not want to have to work on your robot with it built like that. We learned that our rookie year.....the electronics need to be easy to get to, period.
Unread 28-01-2013, 12:41
Jon Stratis's Avatar
Jon Stratis Jon Stratis is online now
Electrical/Programming Mentor
FRC #2177 (The Robettes)
With that setup, you'll make your inspector very unhappy, as they'll have a very difficult time seeing what they need to see.
Rather than reconfigure the board, is it possible to add a hinge on the bottom? Our electrical board is likewise at the very bottom of our robot under other stuff, but we have one side of the board hinged and the other bolted. For inspection, we tip the robot on its side, remove two bolts, and the whole thing is very, very easily visible!
2007 - Present: Mentor, 2177 The Robettes
LRI: North Star 2012-2016; Lake Superior 2013-2014; MN State Tournament 2013-2014, 2016; Galileo 2016; Iowa 2017
2015: North Star Regional Volunteer of the Year
2016: Lake Superior WFFA
Unread 28-01-2013, 12:43
AKA: Billy
Rookie Year: 2007
That's pretty cool. Seems easier to do then what I suggested. I kinda want to see that.
Unread 28-01-2013, 13:12
connor.worley's Avatar
connor.worley connor.worley is offline
FRC #0973 (Greybots)
Rookie Year: 2010
connor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond repute
Last year, motors (along with a lot of other stuff) obscured most of our PD board from view. We didn't have any problems with inspection.
Team 973 (2016-???)
Team 5499 (2015-2016)
Team 254 (2014-2015)
Team 1538 (2011-2014)
2014 Driver (25W 17L 1T)
日本語でOK
Unread 28-01-2013, 13:36
AKA: Billy
Rookie Year: 2007
Even if inspection isnt an issue they still need to be able to reach their electronics with some ease in order to make any adjustments. You always need to plan for the worst and I dont think spending a bunch of time on just reaching the electronics is great especially if they need to make quick repairs or additions during a competition.
Unread 28-01-2013, 15:33
rsisk's Avatar
The GURU Channel
AKA: Richard Sisk
Rookie Year: 2007
I sure like the hinged electronics board idea, makes for easy inspection and service. The wires on the voltage side of the Talons run inside the C-Channel and might make it tough to hinge in our case.
I can reach in with my hands and change breakers. The wago connectors on the non-battery side are positioned so I can fit the screwdriver in and change a wire (the battery side is more difficult, but three bolts and the battery case is off the electronics board).
Metal shavings coming out of the gear boxes is now concerning me as well.
Mounting on top of the transmissions is out because the shooter will be above the transmissions and when down will not leave any room to mount anything up there. When the shooter is up, there is plenty of room to see through the motors. Might have to see if there is a way to raise the shooter to make room for the PDB.
Sure would be nice to have a smaller PDB
Thanks for all the input so far.
Unread 28-01-2013, 15:42
Joe Ross Joe Ross is offline
FRC #0330 (Beachbots)
Rookie Year: 1997
Prior to wiring the robot, we put together a spreadsheet showing the motor, speed controller, wire size, and breaker size. This comes in handy during inspection, because typically the inspector will look at the spreadsheet, and then spot check one or two breakers.
Unread 28-01-2013, 16:02
Conor Ryan Conor Ryan is offline
I'm parking robot yacht club.
FRC #4571 (Robot Yacht Club)
Conor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond repute
Post a picture of the current electronics set up.
Field personnel really need to have easy crio, radio, and main breaker accessibility. Safety is also a significant issue behind this rule.
Also if you plan on hanging, and having anything in zone 3, (even if its a 1/4" of aluminum) make sure you can turn the robot off from the ground easily.
Unread 28-01-2013, 16:15
Grim Tuesday's Avatar
Grim Tuesday Grim Tuesday is offline
AKA: Simon Bohn
FRC #0639 (Code Red)
Rookie Year: 2010
Grim Tuesday has a reputation beyond reputeGrim Tuesday has a reputation beyond reputeGrim Tuesday has a reputation beyond reputeGrim Tuesday has a reputation beyond reputeGrim Tuesday has a reputation beyond reputeGrim Tuesday has a reputation beyond reputeGrim Tuesday has a reputation beyond reputeGrim Tuesday has a reputation beyond reputeGrim Tuesday has a reputation beyond reputeGrim Tuesday has a reputation beyond reputeGrim Tuesday has a reputation beyond repute
Our PD board was pretty obscured last year (we put it vertically behind our collection mechanism) and Big Al gave us a talking to at Champs. It's unlikely they won't pass you because of that considering the amount of work it would take to relocate something the magnitude of the PD board but I can guarantee you the inspectors won't be happy about it. Remember, they say it must be visible for inspection, not visible for gameplay so if you choose to have it mounted on some sort of hinged mechanism it is still legal.
  #15   Spotlight this post!
Unread 28-01-2013, 16:23
rsisk's Avatar
The GURU Channel
AKA: Richard Sisk
Rookie Year: 2007
Main breaker, cRIO, and radio are easily accessible. Will get a pic after work
