Go to Post Thank you GDC, for keeping everyone honest! - dtengineering [more]
Unread 28-01-2013, 16:13
Boombots Boombots is offline
FRC #4058
Boombots is an unknown quantity at this point
magnetic encoders
hey, CD,
i know there are several threads regarding the mounting of the magnetic encoders. However, we are not sure as to how the magnet is mounted upon the motor shaft. is the cap to be drilled to fit (YIKES), or am i overlooking the simple?
Thanks for the feedback
Unread 28-01-2013, 21:04
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Re: magnetic encoders
The magnet will probably stick to the end of the shaft. You just need to find a way to make it stay there.
I used a short length of heat-shrink tubing around the shaft and magnet. The typical post for mounting a US Digital E4P encoder is just the right size for that. Perhaps a drop of an appropriate adhesive would work for you.
Unread 29-01-2013, 02:49
fox46's Avatar
fox46 fox46 is offline
FRC #2013 (Cybergnomes)
Rookie Year: 2000
fox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond repute
The spec sheet recommends keeping the magnet away from ferrous materials so I don't know how happy the encoder will be with the magnet stuck to a steel shaft. Our plan is to machine an aluminum cup where one end is held to the motor shaft using a set screw and the other has a small cup to epoxy the magnet into.
Mentor, Team 2013 Cybergnomes 2010 - 2014, 2016
Mentor, Team 3756 RamFerno 2011 - 2013
Mentor, Team 854 Iron Bears 2005-2007
Founding member, Team 854 Iron Bears 2000-2005
Mech.Eng.+Mgt University of Ontario 2009
B.Ed OCT Trent University 2015
Professional Education and Product Knowledge Consultant - Toyota Canada Inc.
