Go to Post We were also at 9,999 [characters] for Chairmans...Mom always said I was an under-achiever. - Chris Fultz [more]
Unread 28-01-2013, 16:51
Thad House Thad House is online now
Volunteer, WPILib Contributor
no team (Waiting for 2021)
Rookie Year: 2010
Thad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond repute
Unable to use camera set VI's on dashboard
Our team is trying to use the labview VI's to set up the camera in the dashboard. Last year it worked, but when we try adding the camera open VI's to the dashboard this year, it starts importing all of the robot library's and the dashboard will not run after that point. The read Mjpg VI works, but no other camera VI's work from the dashboard. Is there a reason for this change, because it worked last year.
All statements made are my own and not the feelings of any of my affiliated teams.
Teams 1510 and 2898 - Student 2010-2012
Team 4488 - Mentor 2013-2016
Co-developer of RobotDotNet, a .NET port of the WPILib.
Unread 28-01-2013, 23:09
Re: Unable to use camera set VI's on dashboard
The camera VIs were changed in order to support simulation.
I believe that the Camera Open has a parameter than makes it skip calling that stuff.
Greg McKaskle
Unread 29-01-2013, 12:03
Rookie Year: 2010
I tried setting that, and it still didnt work. It still adds all the libraries as dependencies, and then when you build it it does not work correctly. It works if you run the VI manually, but as soon as you build it the executable will not start because it looks for libraries it can not find. Is there a solution to make it not add those dependencies?
Unread 29-01-2013, 16:43
apples000's Avatar
apples000 apples000 is offline
Rookie Year: 2012
apples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant future
We've had the same thing. Were using java on the root, and lv for the dashboard, but this yea we can't put any of the camera set vi's on the dashboard because it loads the simulation stuff. Also, from what we've seen from helping rookie teams in our area, LabView is much slower than last year at loading because of the simulation stuff. Is there a way for all of the simulation tools to be removed from the library?
Unread 29-01-2013, 22:08
If you choose one of the templates without simulation, it shouldn't impact load or build time.
If your project has simulation, you can right-click on the sim files under My Computer target and remove them from the project.
If you are running the dashboard on a computer without the LV development environment, your app will try to load the simulator and that is annoying. You should be able to use the conditional disable structure or delete the code from the Open and use a Save As to give it a dashboard-centric name.
Greg McKaskle
Unread 30-01-2013, 01:45
Rookie Year: 2010
So when you add the camera open vi, it adds all of the simulation files to the project. From that point on, even if you tell the camera open vi to not allow simulation it still tries to use the simulation library's and fails to run. This is all with a clean dashboard project.
Unread 30-01-2013, 07:42
There are two versions of the Camera Open, one for robot and one for PC. The PC version previously was only used for dashboard. This year, it was also used for simulated robots, and the simulated code was added to it. When this was done, a parameter was added to avoid running the simulated code when used for dashboard. But the LV compiler still compiles in the simulated code because it can't tell that you won't call it at some point.
You only need to call Open if you are trying to set camera properties like resolution. These can also be set on the robot. That is what I recommend until the dashboard and simulated camera usage is resolved.
Greg McKaskle
Unread 30-01-2013, 16:50
apples000's Avatar
Rookie Year: 2012
Wow, I completely missed that you could make a project without simulation. Thanks for pointing that out!
