Go to Post Isn't that, April showers bring Woodie Flowers? ;) - jgannon [more]
Unread 01-28-2013, 07:51 PM
momoJr0 momoJr0 is offline
FRC #4209
momoJr0 is an unknown quantity at this point
Speed Controllers Not Working
We are having an awkward issue with our speed controllers.
Our controllers will work as expected until we pass them a value below a certain threshold, at which point they no longer work. For example, this is what happens with the following code:
drive.tankDrive(1,1); //Works normally
drive.tankDrive(.5,.5); //Stops motors. Expected, as they probably just do not have enough voltage to run.
drive.tankDrive(1,1); //Motors no longer run. 0V out of speed controllers.
Once the motors stop we must disenable and reenable to get them to run again.
Team code can be found at:
https://github.com/lwague2/Team4209/...4209Robot.java
NOTE: Due to the way our robot is built and a lack of splitter cables, we have two 2-wheel RobotDrives that we simply pass like values. This seems works as expected and does not seem to be the source of the problem.
