Go to Post It's not about the equipment, it's about the program. - Taylor [more]
Unread 28-01-2013, 22:09
AZDevilRobot AZDevilRobot is offline
FRC #4111 (Some Assembly Required)
Rookie Year: 2012
AZDevilRobot is an unknown quantity at this point
Window Motor Gear Problem
Hi everyone
For my team's disc shooter, we were thinking of using a gear system to angle our shooter. A 72 tooth gear would be attached to the shooter and a 14 tooth gear would be spun by a window motor and turn the big gear. The problem is, the small gear we have has a hex shape hole and won't fit on the window motor because of the shape and because its too big. Do we have to buy a gear specifically for the motor or is there something we can do so the gear will fit?
Thanks for the help
Team 4111
