Centered Hole on frame
Is there a reason there is one hole drilled off center on the channel aluminum for the frame.
We mounted our center wheels on that hole, and it raises our front wheels off of the ground. In turn not letting us have all 6 wheels on the ground at the same time. Can we modify the frame so that all wheels will be flat on the bottom? Or is there a better solution? Thanks |
