Go to Post I'm missing JVN's build log this year ! - lynca [more]
Unread 01-29-2013, 06:36 PM
progal's Avatar
progal progal is offline
Programmer
AKA: Shelby
FRC #0384 (Sparky)
progal is an unknown quantity at this point
Gyro angle increasing while robot is static
We're trying to get the angle during Teleop mode. It worked in the past perfectly, and now every time we enable (and disable) the reading on the Driver Station LCD is rapidly decreasing 1/100th every second. But if the gyro feels like it, it will rapidly increase 1/100th every second.
This is how we're initiating it:
Code:
#include "WPILib.h"
 * This is a demo program showing the use of the RobotBase class.
 * The SimpleRobot class is the base of a robot application that will automatically call your
 * Autonomous and OperatorControl methods at the right time as controlled by the switches on
 * the driver station or the field controls.
class RobotDemo : public SimpleRobot
	RobotDrive myRobot; // robot drive system
	Joystick stick1, stick2; // only joystick
	ADXL345_I2C adxl;
	Gyro gyro;
	Relay *blinkylight;
public:
	RobotDemo(void):
		myRobot(2, 3),	// these must be initialized in the same order
		stick1(1),		// as they are declared above.
		stick2(2),
		adxl(1, ADXL345_I2C::kRange_2G),
		gyro(2)
		myRobot.SetExpiration(0.1);
		blinkylight = new Relay(4);
And this is how we're utilizing it:
Code:
void OperatorControl(void)
		gyro.Reset();
		gyro.SetSensitivity(0.007);
		DriverStationLCD *dsLCD = DriverStationLCD::GetInstance();
		myRobot.SetSafetyEnabled(true);
		bool motorinv = false;
		while (true)
			blinkylight->Set(Relay::kForward);
			ADXL345_I2C::AllAxes ax = adxl.GetAccelerations();
			//printf("X: %f, Y: %f, Z: %f", ax.XAxis, ax.YAxis, ax.ZAxis);
			dsLCD->PrintfLine(DriverStationLCD::kUser_Line1, "X: %f", ax.XAxis);
			dsLCD->PrintfLine(DriverStationLCD::kUser_Line2, "Y: %f", ax.YAxis);
			dsLCD->PrintfLine(DriverStationLCD::kUser_Line3, "Z: %f", ax.ZAxis);
					adxl.GetAcceleration(ADXL345_I2C::kAxis_X));
					adxl.GetAcceleration(ADXL345_I2C::kAxis_Y));
					adxl.GetAcceleration(ADXL345_I2C::kAxis_Z));
			dsLCD->PrintfLine(DriverStationLCD::kUser_Line4, "Gyro: %f", gyro.GetAngle());
			dsLCD->PrintfLine(DriverStationLCD::kUser_Line6, "Motorinv: %d", motorinv);
			dsLCD->UpdateLCD();
			if(stick1.GetRawButton(2) || stick2.GetRawButton(2))
				if(motorinv == false)
					motorinv = true;
				else if(motorinv == true)
					motorinv = false;
			myRobot.SetInvertedMotor(myRobot.kRearLeftMotor, motorinv);
			myRobot.SetInvertedMotor(myRobot.kRearRightMotor, motorinv);
			if((stick1.GetTrigger() == true) && (stick2.GetTrigger() == true))
				myRobot.TankDrive(stick1,stick2);
			else if(stick1.GetTrigger() == true && (stick2.GetTrigger() == false))
				myRobot.ArcadeDrive(stick1);
			else if(stick2.GetTrigger() == true && (stick1.GetTrigger() == false))
				myRobot.ArcadeDrive(stick2);
			else
				myRobot.TankDrive(0.0, 0.0);
			Wait(0.005);				// wait for a motor update time
START_ROBOT_CLASS(RobotDemo);
I guess the question is, what are we doing wrong to get such extreme values? Like I said, this previously worked and we switched out gyros - same problem.
Thank you in advance!
Unread 01-31-2013, 10:27 AM
virtuald's Avatar
virtuald virtuald is offline
RobotPy Guy
AKA: Dustin Spicuzza
FRC #1418 (), FRC #1973, FRC #4796, FRC #6367 ()
virtuald has a brilliant futurevirtuald has a brilliant futurevirtuald has a brilliant futurevirtuald has a brilliant futurevirtuald has a brilliant futurevirtuald has a brilliant futurevirtuald has a brilliant futurevirtuald has a brilliant futurevirtuald has a brilliant futurevirtuald has a brilliant futurevirtuald has a brilliant future
Re: Gyro angle increasing while robot is static
In the past when I've used gyros, this happens when you set the sensitivity incorrectly.
Maintainer of RobotPy - Python for FRC
Creator of pyfrc (Robot Simulator + utilities for Python) and pynetworktables/pynetworktables2js (NetworkTables for Python & Javascript)
2017 Season: Teams #1973, #4796, #6369
Team #1418 (remote mentor): Newton Quarterfinalists, 2016 Chesapeake District Champion, 2x Innovation in Control award, 2x district event winner
Team #1418: 2015 DC Regional Innovation In Control Award, #2 seed; 2014 VA Industrial Design Award; 2014 Finalists in DC & VA
Team #2423: 2012 & 2013 Boston Regional Innovation in Control Award
Resources: FIRSTWiki (relaunched!) | My Software Stuff
Unread 01-31-2013, 11:44 AM
Joe Ross Joe Ross is offline
FRC #0330 (Beachbots)
Rookie Year: 1997
Changing .01 degrees per second is a pretty good drift rate for the gyros that I've worked with. I'm used to more like 0.05 degrees per second.
Unread 01-31-2013, 11:59 AM
Mark McLeod's Avatar
Mark McLeod Mark McLeod is online now
Just Itinerant
AKA: Hey dad...Father...MARK
FRC #0358 (Robotic Eagles)
Is the gyro calibrating with a still robot, e.g., hands-off, no compressor or other vibrating object running.
Unread 01-31-2013, 12:34 PM
Mr. Lim Mr. Lim is offline
AKA: Mr. Lim
Team Role: Leadership
Rookie Year: 1998
Mr. Lim has a reputation beyond reputeMr. Lim has a reputation beyond reputeMr. Lim has a reputation beyond reputeMr. Lim has a reputation beyond reputeMr. Lim has a reputation beyond reputeMr. Lim has a reputation beyond reputeMr. Lim has a reputation beyond reputeMr. Lim has a reputation beyond reputeMr. Lim has a reputation beyond reputeMr. Lim has a reputation beyond reputeMr. Lim has a reputation beyond repute
Seconded...
I think your gyro is working just fine... probably better than ours!
In life, what you give, you keep. What you fail to give, you lose forever...
Unread 01-31-2013, 12:42 PM
Ether's Avatar
Ether Ether is offline
systems engineer (retired)
Rookie Year: 1969
If the drift is bothersome during an extended practice or demo session, add a button to your code so the driver can re-zero the gyro whenever the robot is pointing in the zero direction.
Unread 01-31-2013, 02:30 PM
Iaquinto.Joe's Avatar
Iaquinto.Joe Iaquinto.Joe is offline
RPI 2018
AKA: Joe Iaquinto
FRC #0308 (The Monsters)
Rookie Year: 2011
Iaquinto.Joe is a jewel in the roughIaquinto.Joe is a jewel in the roughIaquinto.Joe is a jewel in the rough
Either this or just reset the gyro before you do an action.
4 year 2011 - 2014 FRC team 308 member, Lead Programmer - C++ / LabVIEW
3 year 2011, 2013, 2014 OCCRA member, Co-Captain OCCRA team 308
  • OCCRA Engineering Excellence - Waterford Kettering 2013
  • Innovation in Control - 2011
  • Quality award- Northville 2012
  • Engineering Excellence- Howell 2014
  • Innovation in Controls- Livonia 2014
Unread 01-31-2013, 02:35 PM
Ether's Avatar
Rookie Year: 1969
That works only if the "action" is intended to be relative to the current position, not if you are using the gyro for true heading (e.g. field-centric control).
Unread 01-31-2013, 11:31 PM
progal's Avatar
Programmer
AKA: Shelby
FRC #0384 (Sparky)
Thank you for all of your help everyone!
We figured it out:
The problem was the wire that provides power for the gyro wasn't plugged in..
But the code above does work, excluding the sensitivity. So we changed that to 0.05 and the gyro works perfectly now.
