Go to Post It is a good idea to try to stand in another person's shoes and treat them as your equal. It's called respect. - Jaine Perotti [more]
Unread 29-01-2013, 19:35
aminnich aminnich is offline
FRC #4028
aminnich is an unknown quantity at this point
Cannot write image to cRIO?
We took the FRC 2013 Vision Example and uncommented the proper lines to write a threshold image to the cRIO. However, I am not seeing this image anywhere.
Here is some relevant code. All of the changes are in here; everything else is unmodified from the template.
Code:
//while (IsAutonomous() && IsEnabled()) {
             * Do the image capture with the camera and apply the algorithm described above. This
             * sample will either get images from the camera or from an image file stored in the top
             * level directory in the flash memory on the cRIO. The file name in this case is "testImage.jpg"
			ColorImage *image;
			//image = new RGBImage("/testImage.jpg");		// get the sample image from the cRIO flash
			camera.GetImage(image);				//To get the images from the camera comment the line above and uncomment this one
			BinaryImage *thresholdImage = image->ThresholdHSV(threshold);	// get just the green target pixels
			thresholdImage->Write("/testImage.jpg");
			BinaryImage *convexHullImage = thresholdImage->ConvexHull(false);  // fill in partial and full rectangles
			//convexHullImage->Write("/ConvexHull.bmp");
			BinaryImage *filteredImage = convexHullImage->ParticleFilter(criteria, 1);	//Remove small particles
			//filteredImage->Write("Filtered.bmp");
			vector<ParticleAnalysisReport> *reports = filteredImage->GetOrderedParticleAnalysisReports();  //get a particle analysis report for each particle
			scores = new Scores[reports->size()];
Anybody have an idea why an image isn't being written to the cRIO?
Unread 29-01-2013, 21:49
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Re: Cannot write image to cRIO?
It looks to me like the entire while loop is commented out.
Unread 30-01-2013, 17:18
FRC #4028
It's commented out because we only want it to write an image once.
Unread 31-01-2013, 09:14
Toa Circuit's Avatar
Toa Circuit Toa Circuit is offline
Thaddeus Maximus
AKA: Thad Hughes
FRC #4213 (MetalCow Robotics)
Team Role: Leadership
Rookie Year: 2012
Toa Circuit is an unknown quantity at this point
Change the .jpg and .bmp extensions to .png, I had the problem you had and this worked for me.
Also, you should uncomment these lines so you can see all the images proccessed:
Code:
2012 Head of Programming and Electrical
2013-14 Overall Team Captain and Programming Head
2012-14 Mentor of FLL Team Power Surge
2014 Dean's List Finalist
2014 CIR Xerox Creativity Award
Webpage
