Go to Post A solution will present itself, all you have to do is be ready to take advantage of it when it does. - James1902 [more]
Unread 29-01-2013, 23:25
jonboy jonboy is offline
Engineer/Mentor
FRC #0885 (The Green Team)
jonboy is an unknown quantity at this point
Max Vision Processing Range?
Does anyone have info regarding max range of the out of the box vision processing LV or JAVA code? We would like to get a handle on Vision processing max range capability under laboratory/competition settings: theoretically, as measured at 1/2 scale, measured full scale, ... Effects of target illumination intensity, field lighting effects, image size, frame rate, color vs monochrome.
TIA
... jon
