Go to Post Remember, FIRST is a great opportunity that will get you ahead in the long run but don't forget about the short run either. - ChrisMcK2186 [more]
Unread 30-01-2013, 08:47
ToddF's Avatar
ToddF ToddF is offline
mechanical engineer
AKA: Todd Ferrante
FRC #2363 (Triple Helix)
Rookie Year: 2011
ToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond repute
2363 prototype pickup arm
This year we decided to focus on scoring high in autonomous, gather disks from the floor when they are available and the feeder when necessary, then hang for 10 points at the end. One key to a high scoring autonomous mode is gathering from the floor. Here is a video of our prototype floor pickup mechanism. While not perfect (it is, after all, a prototype), this has given us the confidence to proceed with final design and fabrication of a competition quality version.
http://www.youtube.com/watch?v=XVD6P...ature=youtu.be
The arm is mounted on our practice bot chassis. The software team has been working with the competition bot drive train for a week and a half (the second key to a high scoring autonomous mode).
Todd F.
mentor, FIRST team 2363, Triple Helix
Photo gallery
video channel
Triple Helix mobile
Unread 30-01-2013, 08:55
JCharlton's Avatar
JCharlton JCharlton is offline
AKA: JC
JCharlton is a splendid one to beholdJCharlton is a splendid one to beholdJCharlton is a splendid one to beholdJCharlton is a splendid one to beholdJCharlton is a splendid one to beholdJCharlton is a splendid one to beholdJCharlton is a splendid one to behold
Re: 2363 prototype pickup arm
Looks great! Hard to tell, will you be inside the 54" cylinder with your bumpers? We were finding it's pretty restrictive.
"There is no problem so bad that you can’t make it worse." - via Chris Hadfield
Unread 30-01-2013, 09:00
Andrew Lawrence
Posts: n/a
Where do the frisbees go from there?
Unread 30-01-2013, 09:07
ToddF's Avatar
mechanical engineer
AKA: Todd Ferrante
Rookie Year: 2011
Our first prototype (over the front bumper) exceeded the cylinder by quite a bit. This one fits the cylinder exactly with the arm horizontal (maximum extent of the arm) and is a little within the cylinder when down on the floor.
The width of the scooper matches the width of our frame, for maximum disk gathering. The length of the arm is the maximum allowable by the cylinder.
Restrictive is an understatement.
Todd F.
Photo gallery
video channel
Triple Helix mobile
Unread 30-01-2013, 09:28
The_ShamWOW88's Avatar
The_ShamWOW88 The_ShamWOW88 is offline
Senior Mentor/Coach
FRC #0157 (Aztechs)
Team Role: Coach
The_ShamWOW88 is a splendid one to beholdThe_ShamWOW88 is a splendid one to beholdThe_ShamWOW88 is a splendid one to beholdThe_ShamWOW88 is a splendid one to beholdThe_ShamWOW88 is a splendid one to beholdThe_ShamWOW88 is a splendid one to beholdThe_ShamWOW88 is a splendid one to behold
What do you guys plan on doing from there? Conveying them to some sort of shooter or do you plan on dumping the low goal?
Great looking design though, works well too!
"The best way to predict the future is design it"
"Striving for excellence through inspiration"
Unread 30-01-2013, 09:39
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
If you were to change the pickup funnel so it's not centered, you could hit 2 discs simultaneously and not worry about the first one clearing before the 2nd disc comes in and jams the whole thing. You may also be able to increase the belt speed on that side slightly such that the offset side rollers pull disc #1 in faster, making it clear the intake before the 2nd disc's apex gets in front of it. It's pretty easy to increase the belt linear speed by increasing its drive roller slightly.
GitHub
Unread 30-01-2013, 10:53
ToddF's Avatar
mechanical engineer
AKA: Todd Ferrante
Rookie Year: 2011
This was our original idea. If the "funnel" is offset, it has to go over top of the bumpers. Without going into a bunch of the other constraints (non-interference with the shooter, shallow scoop angle), an arm that was long enough to go over the bumpers broke the 54" cylinder when horizontal. With a couple more weeks to tweak, we probably could have made it work. But, this year we are following the motto: Having a good robot early is better than having a perfect robot late.
This is one of the things we may try, if jamming proves to be a problem. There are many tiny tweaks possible to speed up one side, or slow down the other.
Todd F.
Photo gallery
video channel
Triple Helix mobile
Unread 30-01-2013, 10:58
TheCrayButton's Avatar
TheCrayButton TheCrayButton is offline
FRC #3528
TheCrayButton has a spectacular aura aboutTheCrayButton has a spectacular aura about
I love it! Nice work! We are hoping to do something similar to this too.
Unread 30-01-2013, 12:59
Kettering's Avatar
Kettering Kettering is offline
read. set. rebound rumble.
AKA: Steve Smitka
FRC #3098 (The Captains)
Kettering is just really niceKettering is just really niceKettering is just really niceKettering is just really niceKettering is just really nice
What kind of belts are you using? Where did you get them?
www.team3098.com
Unread 30-01-2013, 14:16
ToddF's Avatar
mechanical engineer
AKA: Todd Ferrante
Rookie Year: 2011
http://www.mcmaster.com/#endless-flat-belts/=l9hqh3
Splicing: https://www.youtube.com/watch?v=auJt...nVjw& index=4
Todd F.
Photo gallery
video channel
Triple Helix mobile
Unread 30-01-2013, 15:47
BobbyVanNess's Avatar
BobbyVanNess BobbyVanNess is offline
AKA: Bobby Van Ness
FRC #0020 (The Rocketeers)
Rookie Year: 2011
BobbyVanNess is a glorious beacon of lightBobbyVanNess is a glorious beacon of lightBobbyVanNess is a glorious beacon of lightBobbyVanNess is a glorious beacon of lightBobbyVanNess is a glorious beacon of lightBobbyVanNess is a glorious beacon of light
This looks awesome! I've been working on something very similar, only different . Does your bottom plate scrape the ground? If so, how does this affect driving?
2016 TVR Finalists, FLR Champions, Carver Sub-Division
2015 TVR Finalists, Carson Sub-Division Champions, IRI
2014 TVR Champions, FLR Champions, Archimedes Division, IRI
2013 WPI Regional Finalist, Connecticut Regional Champion, Archimedes Division, IRI
2013 Championship and IRI Talent Show winner
2013 - 2014 Driver: 82-43
Lead Strategy Mentor: 32-15
Unread 06-02-2013, 13:25
ToddF's Avatar
mechanical engineer
AKA: Todd Ferrante
Rookie Year: 2011
Competition pickup arm was assembled last night.
Todd F.
Photo gallery
video channel
Triple Helix mobile
