Go to Post Here on CD, we are all one big FIRST team, mentoring each other. - Joe G. [more]
Unread 30-01-2013, 18:59
jalmos jalmos is offline
FRC #4166
jalmos is an unknown quantity at this point
Pneumatic wiring diagram/help
We are having trouble finding a wiring diagram to hook up our Vesto 24V double solenoid. (The sad part is we did it last year and can't remember)
Can anyone give us a hand as to where to plug it into and/or where we could go to find a diagram.
Also we are in need of some advice for the pressure switch electrical hook ups as well.
Any help would be greatly appreciated!!
Jalmos
Unread 30-01-2013, 20:24
ThePlagueDoctor's Avatar
ThePlagueDoctor ThePlagueDoctor is offline
ArduinoFTW
AKA: Anthony
FRC #0375 (The Robotic Plague)
Rookie Year: 2012
ThePlagueDoctor is an unknown quantity at this point
Re: Pneumatic wiring diagram/help
Jalmos
Did you check the products data sheet to see which terminal is which?
Just remember, if a plague comes out of no where.... Well you know where it came from
<a href="http://www.thebluealliance.net/tbatv/team/375" style="border: 0"><img src="http://www.thebluealliance.net/tbatv/teambadge/gen/375/000000/FFCC00/teambadge.png" alt="Team 375" /></a>
Unread 31-01-2013, 01:38
Wildcats1378 Wildcats1378 is offline
Rookie Year: 2011
Wildcats1378 is an unknown quantity at this point
For the solenoids, all you need to do is plug in the wires to the solenoid breakout on the cRIO. They should have 2 wires, a negative and a signal wire. The diagram on the solenoid breakout cover will show you which way to plug in the wire. Then, you've got the program them.
For the digital pressure switch, you have to cut a PWM wire and plug it into the DIO ports on the sidecar.
Unread 31-01-2013, 04:11
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Team Role: Teacher
On a related note, is it legal to ground solenoids - side straight to a ground on the PDB and run two solenoids (or one double solenoid) off a Spike relay?
Unread 31-01-2013, 15:00
FRC #4166
Thanks for the help. We lost all the paper work that came with the solenoid. Would anyone out there be willing to send us a pic of the code to program this into Labview. Using a double solenoid 24v Vesto switch. Thanks again for helping a rookie out!
jalmos
Unread 31-01-2013, 15:01
sarah_storer's Avatar
sarah_storer sarah_storer is offline
Georgia Tech RoboJackets Outreach
AKA: Sarah Storer
FRC #5332 (Toaster Tech)
Rookie Year: 2013
sarah_storer is a splendid one to beholdsarah_storer is a splendid one to beholdsarah_storer is a splendid one to beholdsarah_storer is a splendid one to beholdsarah_storer is a splendid one to beholdsarah_storer is a splendid one to beholdsarah_storer is a splendid one to behold
jalmos
http://team358.org/files/pneumatic/P...RIOversion.pdf
^^ this link was INCREDIBLY helpful for us! We're rookies in pneumatics too
TEAM 3753 BULAH BOTS ALUMNI
2012-2015: Code, pneumatics, and electrical for BULAH BOTS Team 3753
2013: Bayou Regional 1st seed alliance captain and regional winners (With 118 and 4589)
2014, 2015: Bayou Regional semi-finalist
2016-?: Mentor for TOASTER TECH Team 5332
2016: Columbus District 3rd seed alliance captain, semi-finalist; Kennesaw District 3rd seed alliance 1st pick, semi-finalist; Peachtree District State Championship 4th seed alliance captain, quarter-finalist, Industrial Design Award, World Championship qualification
