Go to Post I'll give you my prediction in just over 35 hours. - Andrew Schreiber [more]
Unread 30-01-2013, 21:31
sg763 sg763 is offline
FRC #1452
sg763 is an unknown quantity at this point
Servo for Shooter?
Hi everyone,
I'm not sure if I'm posting this in the right place as this is my very first post! My team is relatively new to FRC and we are trying to building a semi circle for the shooter this year. We seem to have it working pretty well. The only thing we need to tackle next is a "flipper" that pushes the frisbees into the shooter (up until now we've been feeding the frisbees in by hand). We were thinking of mounting a servo onto this flipper and were wondering if anybody had any suggestions as to what type of servo (or other mechanism) we could use? Thanks!
Unread 30-01-2013, 21:36
EricH's Avatar
EricH EricH is offline
New year, new team
FRC #1197 (Torbots)
Re: Servo for Shooter?
The servos we have available in FRC aren't quite up to that task, I think--not enough power. You could try using several working together, but that gets complicated in a hurry.
On the other hand, you did get a window motor in the KOP; those are fairly good "high-power servos" if you program them to run for a very short time on a Spike relay. A short-throw, small-bore, pneumatic cylinder may also be a good option.
Past teams:
2003-2007: FRC0330 BeachBots
2008: FRC1135 Shmoebotics
Unread 30-01-2013, 21:37
ravindran555 ravindran555 is offline
FRC #0610
ravindran555 is an unknown quantity at this point
If you only want to push the Frisbee straight, I would recommend using a pneumatic Piston. If you don't have any pneumatics on your robot, then maybe a servo would be easier for you to implement.
Taran
Unread 30-01-2013, 22:12
z_beeblebrox's Avatar
z_beeblebrox z_beeblebrox is offline
Custom User Title
AKA: Cal
FRC #4183 (Bit Buckets)
Rookie Year: 2012
z_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond repute
The rookie team that we are working with was testing using a servo to feed their shooter today. It seems to work. My team is using pneumatics to maximize power and consistency.
2012 Utah Regional Rookie All-Star
2013 Phoenix Regional Judge's Award for "design process and prototyping"
2014 Hub City Regional Quality Award, Arizona Regional Excellence in Engineering Award
2015 Arizona East Regional Creativity Award, Winner
2016 Arizona North Regional Finalist, Arizona West Excellence in Engineering Award, Finalist
Unread 30-01-2013, 22:17
Orion.DeYoe Orion.DeYoe is offline
FRC #5413 (Stellar Robotics)
Rookie Year: 2011
Orion.DeYoe is a splendid one to beholdOrion.DeYoe is a splendid one to beholdOrion.DeYoe is a splendid one to beholdOrion.DeYoe is a splendid one to beholdOrion.DeYoe is a splendid one to beholdOrion.DeYoe is a splendid one to beholdOrion.DeYoe is a splendid one to beholdOrion.DeYoe is a splendid one to behold
Yeah you're going to be pushing it on power if you try to use a servo. I would recommend a window motor or pneumatics. Another thing to consider is that if you can give the frisbee a little starting momentum then it will make your shooter that much more efficient (all the more reason to go with a more powerful motor).
Unread 30-01-2013, 22:25
EricPalmatier's Avatar
EricPalmatier EricPalmatier is offline
FRC #0250 (The Dynamos!)
Rookie Year: 2000
EricPalmatier is a splendid one to beholdEricPalmatier is a splendid one to beholdEricPalmatier is a splendid one to beholdEricPalmatier is a splendid one to beholdEricPalmatier is a splendid one to beholdEricPalmatier is a splendid one to behold
Send a message via AIM to EricPalmatier
You could always use an electric solenoid with some sort of lever attached. I know several teams are giving that a shot, and it can give you the flip you need without needing to go overboard with a window motor or adding all the extra weight and complexity of a pneumatics system ( assuming you don't already have pneumatic systems on your robot).
If you DO have pneumatics on your robot, then I would say go with a small pneumatic cylinder. can't beat it for speed/weight/force combination! Good luck!
"Engineering is a great profession. There is the satisfaction of watching a figment of the imagination emerge through the aid of science to a plan on paper. Then it moves to realization in stone or metal or energy. Then it brings homes to men or women. Then it elevates the standard of living and adds to the comforts of life. This is the engineer's high privilege."
-Herbert Hoover
