When building our software, I couldn't find an input for where the compressor goes, like when you have a motor, it has an input for a PWM slot, but I didn't find anything on the compressor. does anyone have any ideas what is wrong? All responses are accepted... written, diagram, or otherwise.
Re: Labview compressor problems
The compressor code is in the Timed Tasks VI it has a disable structure around it. It is designed to be connected to a spike relay witch connects to a PWM port
I'm confused what you mean... Could you explain it more clearly?
Here's an example:
![]() The compressor connects to a Spike. The Spike is controlled from Relay 1 (in this example) on the Digital sidecar. Digital Input 1 is where the pressure sensor connects on the Digital sidecar. |
