Go to Post So why are we trying to go to Mars? It's because it's bigger, better, and bolder. Doing what nearly no other team can do, and defying all those who say it can't be done. That reward is a lot more than 9 points. - Mike [more]
Unread 30-01-2013, 21:45
Paul T.'s Avatar
Paul T. Paul T. is offline
no team (Team WARP)
Rookie Year: 2012
Paul T. is on a distinguished road
pic: Team 1687 Doherty Technical Forces - Chassis
Yes its under 112"
Unread 30-01-2013, 21:47
AllenGregoryIV's Avatar
AllenGregoryIV AllenGregoryIV is online now
Engineering Coach
AKA: Allen "JAG" Gregory
FRC #3847 (Spectrum)
Team Role: Coach
AllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond repute
Send a message via AIM to AllenGregoryIV
Re: pic: Team 1687 Doherty Technical Forces - Chassis
What was the intent of the two inset back wheels?
Team 647 | Cyber Wolf Corps | Alumni | 2003-2006 | Shoemaker HS
Team 2587 | DiscoBots | Mentor | 2008-2011 | Rice University / Houston Food Bank
Team 3847 | Spectrum | Coach | 2012-20... | St Agnes Academy
LRI | Alamo Regional | 2014-20...
"Competition has been shown to be useful up to a certain point and no further, but cooperation, which is the thing we must strive for today, begins where competition leaves off." - Franklin D. Roosevelt
Unread 30-01-2013, 21:52
Paul T.'s Avatar
no team (Team WARP)
Rookie Year: 2012
Originally Posted by AllenGregoryIV View Post
I hate to be the person to ask but do you have 8" of bumpers on the two front outside vertices, it looks really small in the picture.
Also, what was the intent of the two inset back wheels?
the front two pieces are 8.5" and the back two tucked in wheels allows us to make our bumpers go like this
l l
\_/
it allows us to fit in the cylinder better.
ROOKIE Team 5400 WARP Mentor
Former FRC 1687 Highlander Robotics
Metal of Honor - Battle Cry 13 @ WPI
WPI districts Semifinalists-2014
Unread 30-01-2013, 21:54
dodar's Avatar
dodar dodar is offline
FRC #1592 (Bionic Tigers)
Rookie Year: 2007
dodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond repute
Maybe I just cant visualize the bumpers but I dont see the point of having those back wheels inboard. That also looks like it will greatly affect the maneuverability of the robot.
1592(Student and Mentor) 2007-2012
Blue Banners: 2008 Colorado, 2012 Orlando, 2012 South Florida, 2014 Orlando, 2015 Buckeye
Mechanical Engineering - University of Central Florida(Class of 2016)
Unread 30-01-2013, 21:57
Paul T.'s Avatar
no team (Team WARP)
Rookie Year: 2012
Yeah we thought it may, but were pretty certain that it will be ok.
were also using 4 CIMS and an andymark to power it so we have the power to make up for it
Unread 30-01-2013, 21:58
EricH's Avatar
EricH EricH is online now
New year, new team
FRC #1197 (Torbots)
You might ask 179 how having wheels offset in a similar pattern affected them a few years back. I think it was their 2005 robot that had 6 wheels in a diamond-ish pattern; it did fairly well.
It doesn't do much to affect maneuverability, not at that level, at least that I know about.
Visualizing the bumpers... It sounds like an interesting idea; I assume that bumper supports just aren't shown in this render. (Magic doesn't count as a support, sorry. Neither does simply constraining in CAD...)
Past teams:
2003-2007: FRC0330 BeachBots
2008: FRC1135 Shmoebotics
Unread 30-01-2013, 22:00
Paul T.'s Avatar
no team (Team WARP)
Rookie Year: 2012
you only see the chassis in the picture, we are planning to use the full 20 lbs for bumpers to include almost all mounting in the bumpers.
Unread 30-01-2013, 23:20
Engineering Coach
Team Role: Coach
I'm still not sure if I understand this comment with how I understand R29.
The bumper hardware can be extensive but there still has to be a frame perimeter for which the bumpers are supported against. When you wrap the string around your robot with out the bumpers where does the frame perimeter support your bumpers?
Unread 31-01-2013, 09:47
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
I agree with Allen. The bumpers (or any attached bumper hardware) do not define the frame perimeter -- only what's on the robot defines the frame perimeter.
Originally Posted by Glossary of the FRC Manual
FRAME PERIMETER: the polygon defined by the outer-most set of exterior vertices on the ROBOT (without the BUMPERS attached) that are within the BUMPER ZONE. To determine the FRAME PERIMETER, wrap a piece of string around the ROBOT at the level of the BUMPER ZONE - the string describes this polygon.
Since your wheels & axles define your perimeter, the plywood backing of the bumpers must butt up against them at every exterior vertex per R22.
Additionally, that is definitely a bit of stretch for the definition of "bumper mounting hardware" that I wouldn't stake my season on without a clearer definition from Q&A.
Fortunately, it looks like it's easy to accommodate hard mounts on the frame itself for bumpers & a frame perimeter everywhere except the front corners. Quite honestly, nothing defines what materials hard frame mount must be made out of, so it can technically be 1/32" sheet metal for the front corners.
The perimeter shape in a nice way of ensuring the 112" distance is met. Kudos to whomever thought of that idea on your team!
GitHub
Unread 31-01-2013, 12:15
Nuttyman54's Avatar
Nuttyman54 Nuttyman54 is offline
Mentor, Tactician
AKA: Evan "Numbers" Morrison
FRC #5803 (Apex Robotics) and FRC #0971 (Spartan Robotics)
Nuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond repute
Send a message via AIM to Nuttyman54
I think this is what Joe is referring to. What's shown is only about 4" tall, they have quite a bit of room in the 6" of bumper zone above that to put a "frame perimeter". They'll be putting small/thin frame members in this area to meet the perimeter/frame rules, but the majority of the structure behind the bumpers is part of their mounting hardware.
Unread 31-01-2013, 13:13
The_ShamWOW88's Avatar
The_ShamWOW88 The_ShamWOW88 is offline
Senior Mentor/Coach
FRC #0157 (Aztechs)
Team Role: Coach
The_ShamWOW88 is a splendid one to beholdThe_ShamWOW88 is a splendid one to beholdThe_ShamWOW88 is a splendid one to beholdThe_ShamWOW88 is a splendid one to beholdThe_ShamWOW88 is a splendid one to beholdThe_ShamWOW88 is a splendid one to beholdThe_ShamWOW88 is a splendid one to behold
Looks like a unique design. Can't wait to see it in action at WPI.
"The best way to predict the future is design it"
"Striving for excellence through inspiration"
Unread 31-01-2013, 13:40
Jeffrafa's Avatar
Jeffrafa Jeffrafa is offline
Robotics Addict
AKA: Jeff Lewis
FRC #1425 (Error Code)
Jeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant future
On a slightly different note, do I spot two pneumatic actuators on each gearbox?
And a pretty interesting layout of 4 larger actuators in the top view, I am very curious to see how this turns out.
Good luck!
Team 1425 Alumnus and Mentor
I am KF7JDK - What's your callsign?
Unread 30-01-2013, 22:04
dodar's Avatar
Rookie Year: 2007
I do believe 179 did it in 2008 as well. They had a pretty wicked turn rate. But it might have just been a 3-wheeler with the front wheel being a swerve module.
Unread 30-01-2013, 22:10
Paul T.'s Avatar
no team (Team WARP)
Rookie Year: 2012
http://www.chiefdelphi.com/media/photos/21631
that's actually what inspired it.
  #15   Spotlight this post!
Unread 30-01-2013, 22:21
dodar's Avatar
Rookie Year: 2007
Well that was their 2005 bot not 2008.
