Go to Post The world is run by those who show up. - AdamHeard [more]
Unread 30-01-2013, 21:54
Ivanoff's Avatar
Ivanoff Ivanoff is offline
AKA: Benson
FRC #0253 (MRT)
Team Role: Leadership
Rookie Year: 2010
Ivanoff is an unknown quantity at this point
Attaching a CIM to Pneumatic Tires
we here at team 253 are trying to figure out how to attach an 8 inch andymark pneumatic tire (am-0970) to a CIM. How would we go about doing this? Preferably in laymen's terms. Sorry about technical ignorance, we're a fairly inexperienced team and we lack significant mentorship.
Unread 30-01-2013, 21:58
Phyrxes's Avatar
Phyrxes Phyrxes is offline
Has done the math, have you?
AKA: Dave Button
no team (No Team, Changed Schools)
Team Role: Teacher
Rookie Year: 2007
Phyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant future
Re: Attaching a CIM to Pneumatic Tires
One of the more common methods is to purchase Hub that slides over the CIM output shaft, with a key, and bolts to the wheel just like a sprocket or pulley would. However you will need to retain the wheel somehow, and make sure you balance it or it might "death wobble."
Link: http://www.andymark.com/product-p/am-0320.htm
Dave Button
Physics and Mathematics Teacher
Wakefield School
The Plains, VA
“Simplify and add lightness.”
― Colin Chapman, Team Lotus
Unread 30-01-2013, 21:59
Peyton Yeung's Avatar
Peyton Yeung Peyton Yeung is offline
45 Alumni
AKA: Peyton Yeung
FRC #0461 (Westside Boiler Invasion)
Team Role: Coach
Peyton Yeung has a reputation beyond reputePeyton Yeung has a reputation beyond reputePeyton Yeung has a reputation beyond reputePeyton Yeung has a reputation beyond reputePeyton Yeung has a reputation beyond reputePeyton Yeung has a reputation beyond reputePeyton Yeung has a reputation beyond reputePeyton Yeung has a reputation beyond reputePeyton Yeung has a reputation beyond reputePeyton Yeung has a reputation beyond reputePeyton Yeung has a reputation beyond repute
You could mount the wheel to an 8mm key hub from andymark. Then put the hub on the output of the cim motor. Then put an 8 mm retaining ring clip (andymark) on the cim shaft. That will connect them
461 Westside Boiler Invasion
2016 Tippy Quarter finalist, Warren Finalist, IN State Semi Finalist,B^3 Double Finalist
2015 Indy Semi finalist, Purdue Quarter Finalist, IN State Quarter Finalist, CORI QF, R2OC Finalist, RAGE Winner
2014 Boilermaker Semi finalist, Crossroads Quarter Finalist, & CAGE Quarter Finalist
45 Technokats
2013 Boilermaker Quarter finalist
2012 CAGE Semi finalist & Queen City Champion
2011 CAGE Quarter finalist & Midwest Semi finalist
2010 CAGE Quarter finalist, Boilermaker Champion, & Washington DC Quarter Finalist
Unread 30-01-2013, 22:08
jaydoorly jaydoorly is offline
AKA: Jay Doorly
FRC #1099 (Disco Techs)
Rookie Year: 2011
jaydoorly is an unknown quantity at this point
Try this hub...
[url=http://www.andymark.com/product-p/am-0320.htm[/URL]
or the 1::2 or 1::6 Spin Box gearbox.
I have found the wobble may be overcome by carefully centering the hub on the wheel.
Have fun!
Unread 30-01-2013, 23:07
DonRotolo's Avatar
Back to humble
FRC #0832
Remember that the CIM will get very unhappy if the other end of a wheel shaft is not held with a bearing. So on the other side of the wheel from the CIM, make sure you mount a bearing there.
ken.3038 ken.3038 is offline
FRC #3038 (I.C.E.)
ken.3038 is an unknown quantity at this point
To save you some time our team tried the AndyMark Hub but the wobble factor egg shaped the hole on the hub. Then we tried to reuse the hub by drilling it out to 3/8" and rigged up a belt drive with a 1:1 ratio. That to failed mostly due poor drilling and not enough support. We now are waiting for this http://www.vexrobotics.com/vexpro/ge...planetary.html which can be changed to 1:1. Using a hex hub and locking collars from AndyMark. We are also an inexperienced team and got the idea from another post hoping this will work for us.
Unread 31-01-2013, 14:25
Orion.DeYoe Orion.DeYoe is offline
FRC #5413 (Stellar Robotics)
Rookie Year: 2011
Orion.DeYoe is a splendid one to beholdOrion.DeYoe is a splendid one to beholdOrion.DeYoe is a splendid one to beholdOrion.DeYoe is a splendid one to beholdOrion.DeYoe is a splendid one to beholdOrion.DeYoe is a splendid one to beholdOrion.DeYoe is a splendid one to beholdOrion.DeYoe is a splendid one to behold
Originally Posted by ken.3038 View Post
Although not as simple as using an Andymark hub (which is probably your best option) you can try mounting the CIM to a VersaPlanetary. Our team did that (to attach to another kind of wheel) and it works great. 3847 gave some basic instructions here.
I would advise milling a .50 inch spacer block (in place of the motor mounting plate) and then cutting the motor shaft to the proper length. This is will give you more shaft and prevent you from having to cut the keyway back farther than it was originally.
Unread 31-01-2013, 15:20
Lil' Lavery Lil' Lavery is offline
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Lil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond repute
Send a message via AIM to Lil' Lavery
A couple other AndyMark products worth mentioning in this thread:
http://www.andymark.com/product-p/am-0472.htm
http://www.andymark.com/product-p/am-0588.htm
Not an all-in-one solution, but it may be useful to many teams contemplating how to attach their CIMs to their shooter wheels.
Unread 31-01-2013, 16:45
pilum40 pilum40 is offline
Steve Miller-Coach-Team 3355
AKA: Steve Miller
FRC #3355 (Bigg Redd)
Team Role: Coach
Rookie Year: 2010
pilum40 has much to be proud ofpilum40 has much to be proud ofpilum40 has much to be proud ofpilum40 has much to be proud ofpilum40 has much to be proud ofpilum40 has much to be proud ofpilum40 has much to be proud ofpilum40 has much to be proud ofpilum40 has much to be proud of
Here's how we did it. 8mm retaining clip from Andymark on CIM, 8mm hub as others have recommended. We fabricated our motor mount locally. Hope this helps a little!
Team 3355
Pic 1:
Pic 2:
Pic 3:
Unread 31-01-2013, 18:06
George C's Avatar
George C George C is offline
AKA: George Chisholm
FRC #1360 (Orbit Robotics)
George C is a splendid one to beholdGeorge C is a splendid one to beholdGeorge C is a splendid one to beholdGeorge C is a splendid one to beholdGeorge C is a splendid one to beholdGeorge C is a splendid one to beholdGeorge C is a splendid one to behold
We turned a 4-5" piece of 1/2" hex aluminum down to 3/8 or 7/16 but left a taper at the shoulder and threaded to accept a hex nut. We then drilled out the end to match the CIM shaft. Using a 3/32 slit saw in a vertical mill, we machined 4 slots to make a collet. The hex shaft fits a hub as shown. It works well and hasn't slipped so far.. In assembly it will have loctite. A bearing captures the other end of the shaft.
http://www.chiefdelphi.com/forums/at...d=13596734 16
