Go to Post Why does kick off take so long to get here but ship date comes toooooooooo fast? - Steve W [more]
Unread 31-01-2013, 13:00
gitlitz gitlitz is offline
FRC #4590
gitlitz is an unknown quantity at this point
Problem with the compressor class
Hey, I am from team 4590.
We are having trouble with the compressor- it does nothing.
The pressure switch is connected to DigitalInput 1 and the Spike to Relay 2.
This is our full simple code:
note: when we use the Relay.Set() function (and don't use the Compressor class at all) the compressor works.
Code:
#include "WPILib.h"
class RobotDemo : public SimpleRobot
	Joystick stick;
	Compressor comp;
public:
	RobotDemo(void):
		stick(1),
		comp(1,2)
		comp.Start();
	void Autonomous(void)
		Wait(2.0);
	void OperatorControl(void)
		while (IsOperatorControl())
			Wait(0.005);
	void Test() {
START_ROBOT_CLASS(RobotDemo);
Unread 31-01-2013, 13:12
Joe Ross Joe Ross is offline
FRC #0330 (Beachbots)
Rookie Year: 1997
Re: Problem with the compressor class
How is the pressure switch wired?
Unread 02-02-2013, 11:06
bob.wolff68's Avatar
bob.wolff68 bob.wolff68 is offline
Da' Mentor Man
FRC #1967
Rookie Year: 2007
bob.wolff68 is just really nicebob.wolff68 is just really nicebob.wolff68 is just really nicebob.wolff68 is just really nicebob.wolff68 is just really nice
I believe the problem is that you won't have any effect on things if you do your comp.Start() from the constructor - RobotDemo(). It is much more normal to see the starting of the compressor at the beginning of OperatorControl() outside of the while loop. And if you need the compressor in Autonomous, you would also call comp.Start() in the beginning of Autonomous().
bob
Bob Wolff - Software from the old-school
Mentor / C / C++ guy
Team 1967 - The Janksters - San Jose, CA
Unread 03-02-2013, 04:06
mikets's Avatar
mikets mikets is online now
Software Engineer
FRC #0492 (Titan Robotics)
mikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of light
bob
Our code calls compressor start in the robot class constructor. It works fine. Compressor takes time to charge up the air tanks so you would want to start the compressor as soon as possible. If not the robot constructor, it should be at least the beginning of RobotInit.
Unread 03-02-2013, 15:28
FRC #4590
Thank you for answering.
I have started the compressor in the OperatorControl() and it worked, but then I tried again to start it in the ctor and it also worked.
I have tried to look for the problem and I saw that it only works when I instantiate a RobotDrive. Can it be or is it just a coincidence?
Unread 03-02-2013, 19:46
Rookie Year: 1997
If you digitital side car is not properly wired, I could see trying to run multiple PWMs cause a problem with reading the pressure switch.
Unread 04-02-2013, 15:00
FRC #4590
It turn out one of the wires of the pressure switch was not connected properly.
Once we fixed it the Compressor started and stopped as expected.
Thank you for your help.
