Go to Post Give me enough gearboxes and I'll move the world. - SenorZ [more]
Unread 31-01-2013, 15:05
Avihu Avihu is offline
FRC #4661
Avihu is an unknown quantity at this point
Volts Problem
hello
when we run the program on our robot the volts Values stays on 0.00 .. what could be the problem?
Unread 31-01-2013, 15:07
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: Volts Problem
You probably either did not connect the wires from the power distribution board to the analog bumper, or you did not add the jumper on the analog bumper.
Unread 31-01-2013, 15:34
FRC #4661
Re: Volts Problem
umm.. where does the jumer goes? I mean on the analog there are several pins..
wich should i use/cover..?
Unread 31-01-2013, 15:37
MrForbes's Avatar
AKA: Jim
Re: Volts Problem
R71 in the Game Manual.
Unread 31-01-2013, 15:38
Jon Stratis's Avatar
Electrical/Programming Mentor
FRC #2177 (The Robettes)
Re: Volts Problem
In the picture on the first page here you'll see the entire analog breakout. In the top left corner of the image there are 3 exposed pins, spaced so they would fit a normal PWM wire. Place a 2-pin jumper over the two pins on the left of the picture - in other words, the two pins closest to the side edge of the board.
2007 - Present: Mentor, 2177 The Robettes
LRI: North Star 2012-2016; Lake Superior 2013-2014; MN State Tournament 2013-2014, 2016; Galileo 2016; Iowa 2017
2015: North Star Regional Volunteer of the Year
2016: Lake Superior WFFA
