Go to Post Certainly more interesting to watch than driving around in circles on a flat field. Sorry, 2008. - synth3tk [more]
Unread 31-01-2013, 18:38
Ether's Avatar
Ether Ether is offline
systems engineer (retired)
Rookie Year: 1969
remainder function
Does the C++ compiler used for FRC support the REMAINDER operator "x REM y" per IEC 60559
as specified on Page 235 Section 7.12.10.2 of ISO/IEC 9899:TC3 ?
If someone would be willing to test that with y=360
and x values of 179, 180, 181, 359, 721, -1, -179, -180, -359, -361, -721
and post results it would be much appreciated.
Unread 31-01-2013, 22:48
sur sur is offline
AKA: Sujit Rao
FRC #3324 (Metrobots)
Rookie Year: 2011
sur is an unknown quantity at this point
Re: remainder function
It seems to be defined if you use the C compiler, but not the C++ one. You could use fmod, which has slightly different behavior.
You can test it out here: http://codepad.org/86MlmNXU
Unread 01-02-2013, 00:41
Ether's Avatar
Rookie Year: 1969
fmod(x,y) is quite different from remainder(x,y)
The 3 columns below are x, remainder(x,360), and fmod(360):
Code:
 180.000     -180.000      180.000
 181.000     -179.000      181.000
-181.000      179.000     -181.000
 359.000       -1.000      359.000
-359.000        1.000     -359.000
 719.000       -1.000      359.000
-719.000        1.000     -359.000
Unread 01-02-2013, 09:18
nightpool's Avatar
nightpool nightpool is offline
robotRectifier
AKA: Evan
no team (formerly of CORE 2062)
Rookie Year: 2011
nightpool is on a distinguished road
What's the issue with using the modulus operator instead of the built-in remainder function?
Proud alum of CORE 2062.
www.core2062.com
Unread 01-02-2013, 09:24
Ether's Avatar
Rookie Year: 1969
Are you saying there is a remainder function in the C++ compiler used for FRC?
Unread 01-02-2013, 11:54
sur sur is offline
AKA: Sujit Rao
Rookie Year: 2011
It looks like you need to define it using extern "C" for WindRiver to compile it correctly:
Code:
#include <cmath>
using namespace std;
extern "C" double remainder(double, double);
Unread 01-02-2013, 12:35
Racer26 Racer26 is offline
Racer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond repute
There's definitely a modulus division operator, which amounts to the same thing.
719 % 360 = 359
Unread 01-02-2013, 12:57
nightpool's Avatar
robotRectifier
AKA: Evan
Rookie Year: 2011
719 % 360 = 359
Right, but it rounds the same as fmod() (see http://www.gnu.org/software/libc/man...Functions.html). I don't have enough experience to say when this would be more or less useful in practice, but if you DO need it extern "C" seems to be the way to go about it.
www.core2062.com
Unread 01-02-2013, 13:01
Ether's Avatar
Rookie Year: 1969
719 % 360 = 359
The modulus division operator is *not* the same thing as the remainder function.
remainder(719,360) is -1, not 359.
Look at the definition of the remainder function which I attached to the original post in this thread.
Unread 01-02-2013, 13:21
OK, so do this instead:
Code:
output = (719 % 360 > 180) ? (-360 + (719 % 360)) : (719 % 360);
Unread 01-02-2013, 13:38
Cal578 Cal578 is offline
Passionate FIRST-er, CD donor
AKA: Gerry
FRC #0578 (Red Raider Robotics)
Cal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant future
I can see how the remainder function would be useful in certain cases, except that I don't like the name of the function. It's non-intuitive, and the results would surprise many people who look at the code after the original writer. When I think back to when I learned division in elementary school, the remainder of two positive numbers was always positive (or zero). I'm trying to think of what I would have named that function, to be more in line with its return values.
Cal
R3: Red Raider Robotics (FRC Team 578)
Fairport, NY, USA
www.FairportRobotics.org
2016 Finger Lakes Regional: Semifinalist on Alliance 7 (1128, 2010, 578)
2016 NYC Regional: Finalist on Alliance 3 (3419, 578, 3017), 4th seed team, Team Spirit Award
2015 Finger Lakes Regional: 8-3-0 in qualification, 7th seed, Quarterfinalist
2014 NY Tech Valley Regional: 8-4-0 in qualification, 13th seed, Semifinalist
2013 Finger Lakes Regional: 4-5-0 in qualification, 26th seed, Alliance 6, 1-2 in tournament
2012 Buckeye Regional: Gracious Professionalism Award, 7-3-0, 14th seed
2011 Finger Lakes Regional: Engineering Inspiration Award
Unread 01-02-2013, 13:40
nightpool's Avatar
robotRectifier
AKA: Evan
Rookie Year: 2011
The "normal" name for this function is drem(), which I think is a contraction of d-something and remainder.
www.core2062.com
Unread 01-02-2013, 13:45
Ether's Avatar
Rookie Year: 1969
"Normal" according to whom? Link please.
Unread 01-02-2013, 13:47
AKA: Gerry
"Delta Remainder" sounds cool. At least when I see drem, I would expect slightly different behavior, thus obeying the programming law of Minimize Surprise.
Cal
Fairport, NY, USA
  #15   Spotlight this post!
Unread 01-02-2013, 13:55
nightpool's Avatar
robotRectifier
AKA: Evan
Rookie Year: 2011
GNU libc. See the link in my previous post.
www.core2062.com
