Go to Post If there's one thing I've learned, it's that the robot is never truly finished. - Joseph Smith [more]
Unread 01-02-2013, 16:41
jake517 jake517 is offline
FRC #4294
jake517 is an unknown quantity at this point
pneumatic compressors?
Last year for our rookie season, we saw many veteran teams charging their air tanks with pneumatic compressors back in their pit areas. Perhaps, we didn't see correctly as to what teams were doing, but we would definitely like to know...
Are we allowed to use pneumatic compressors off our robot to charge our air cylinders, or is this illegal?
Thanks in advance,
~4294
Unread 01-02-2013, 16:42
kevin.li.rit's Avatar
kevin.li.rit kevin.li.rit is offline
Imaginary Friend
AKA: Kevin Li
FRC #0596 (SciClones)
Team Role: Student
kevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond repute
Send a message via Yahoo to kevin.li.rit
Re: pneumatic compressors?
Thanks in advance,
~4294
This is legal provided you control the compressor with the robot CRIO and properly wired spike.
Kevin Li
596 - Sciclones
1405 - Finney Falcons
2262 - Holliston Panthers
Unread 01-02-2013, 16:45
FRC #4294
So, does that mean we can use an additional compressor to the compressor that is on the robot?
Unread 01-02-2013, 16:46
Kevin Sevcik's Avatar
Kevin Sevcik Kevin Sevcik is online now
(Insert witty comment here)
FRC #0057 (The Leopards)
Rookie Year: 1998
It's legal provided you're using only one of the exact same compressor that you'd be using on your robot. And you have to wire it up with a pressure switch, to be controlled by the cRIO. Basically, your off-board compressor has to be exactly the same as the on-board one, except you detach it from the robot and don't run with it during a match.
If you saw anyone charging their robot with a shop air compressor, you should let them know that's not legal and help them rig up an FRC legal air compressor.
Unread 01-02-2013, 16:49
Rookie Year: 1998
No.
Originally Posted by R80
Compressed air on the ROBOT must be provided by one and only one compressor. Compressor specifications may not exceed nominal 12VDC, 1.05 cfm flow rate. Off-board compressors must be controlled and powered by the ROBOT.
I suppose you could use an off-board compressor instead of your on-board compressor. Provided your onboard compressor is disconnected and disabled and the off-board one was poweredand controlled like your now disabled onboard compressor. Except what would be the point at that point?
Unread 01-02-2013, 17:25
rsisk's Avatar
rsisk rsisk is offline
The GURU Channel
AKA: Richard Sisk
FRC #2493 (Robokong)
Rookie Year: 2007
Interesting couple of threads going discussing the same topic.
Over in the other thread, Al S. emphasized that fact that ONLY ONE compressor can be used. You cannot have one on-board and one not on-board at the same time.
http://www.chiefdelphi.com/forums/sh...54&postcount=9
The views expressed are mine and should not be construed to represent the views of anyone else.
Unread 01-02-2013, 21:32
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
Thank you. That is correct. Please also review the rules that reference inspections in Sections 3, 4, and 5.
Al
WB9UVJ
www.wildstang.org
________________________
