Go to Post Anyone else think we're (including me) a little obsessed? The seasons over and were already onto the next one. - Bjenks548 [more]
Unread 01-02-2013, 20:12
ming08108 ming08108 is offline
FRC #4795
ming08108 is an unknown quantity at this point
Shooter Problems
We are just using a CIM mounted on plywood connected to the robot with a 8mm hub 8" pneumatic wheels.
We had some questions.
How do we stop the wheels from going up? (securing it from coming off?)
What is the best way to build up form the KOP base we are using the narrow 6 wheel. We also have some donated 80-20 extrusion.
Also the hubs do not make a tight fit on the motor shaft is this normal?
http://www.andymark.com/product-p/am-0320.htm
http://www.andymark.com/product-p/am-1121.htm
Video for reference.
http://www.youtube.com/watch?v=EbTQwWUjAoo
Unread 01-02-2013, 21:21
blackrocks0 blackrocks0 is offline
AKA: Chaitanya Chittineni
FRC #2264 (Inceptus)
Team Role: Mechanical
Rookie Year: 2010
blackrocks0 is an unknown quantity at this point
Re: Shooter Problems
I think that the best, and easiest, way to secure them is to use set screws. Drill a hole in your hub and use a tap to thread it, then put a set screw in it and secure the wheel to the axle.
Unread 02-02-2013, 06:52
Peyton Yeung's Avatar
Peyton Yeung Peyton Yeung is online now
45 Alumni
AKA: Peyton Yeung
FRC #0461 (Westside Boiler Invasion)
Team Role: Coach
Peyton Yeung has a reputation beyond reputePeyton Yeung has a reputation beyond reputePeyton Yeung has a reputation beyond reputePeyton Yeung has a reputation beyond reputePeyton Yeung has a reputation beyond reputePeyton Yeung has a reputation beyond reputePeyton Yeung has a reputation beyond reputePeyton Yeung has a reputation beyond reputePeyton Yeung has a reputation beyond reputePeyton Yeung has a reputation beyond reputePeyton Yeung has a reputation beyond repute
I'd say use a retaining clip. AndyMark sells them to keep gears on the cim and the also work with hubs.
461 Westside Boiler Invasion
2016 Tippy Quarter finalist, Warren Finalist, IN State Semi Finalist,B^3 Double Finalist
2015 Indy Semi finalist, Purdue Quarter Finalist, IN State Quarter Finalist, CORI QF, R2OC Finalist, RAGE Winner
2014 Boilermaker Semi finalist, Crossroads Quarter Finalist, & CAGE Quarter Finalist
45 Technokats
2013 Boilermaker Quarter finalist
2012 CAGE Semi finalist & Queen City Champion
2011 CAGE Quarter finalist & Midwest Semi finalist
2010 CAGE Quarter finalist, Boilermaker Champion, & Washington DC Quarter Finalist
