Go to Post It's over, done, let's move on and be positive. Next year maybe everything will be perfect. :cool: - Ed Sparks [more]
Unread 02-01-2013, 08:45 PM
Fifthparallel Fifthparallel is offline
AKA: Sam Chen
FRC #1410
Rookie Year: 2011
Fifthparallel is an unknown quantity at this point
DefaultCommand won't restart?
Hey, I run SetDefaultCommand(new [insert default command]()); but whenever I run a command that interrupts it (cancels default command), the default command will not restart. I have tried calling InitDefaultCommand inside of End() of the interrupting command, but this will not start the default command.
Can anybody tell me how to restart the default command after another command interrupts it?
sudo chmod u+x helloworld.sh
gotta start somewhere.
Unread 02-03-2013, 09:14 PM
William Kunkel William Kunkel is offline
Programming Lead
AKA: Kunkel
FRC #0422 (Mech Tech Dragons)
Rookie Year: 2011
William Kunkel is an unknown quantity at this point
Re: DefaultCommand won't restart?
Can you post some code? Also, are you sure the interrupting command ends when you think it does?
Unread 02-04-2013, 01:39 AM
AKA: Sam Chen
FRC #1410
Rookie Year: 2011
Sorry for not posting the solution I found!
Long story short, I needed to call SetExpiration(double X.Y) and SetSafetyEnabled(false) for the RobotDrive object.
The example I was trying to play with/test was basic ArcadeDrive, and a command that would drive the motors forward for 5 seconds. SetSafetyEnabled(true) with no SetExpiration(double X.Y) was called for the RobotDrive object initialization for the subsystem. The command would set the RobotDrive object (which I'll just call *drive) to drive->Drive(0.7) and SetTimeout(5) in the Initialize method of the command. Then, IsFinished would return IsTimedOut().
At runtime, whenever the button that spawned this command was called, the diagnostics tab would spit out errors about motors exceeding a timeout at line 117 of MotorSafetyHelper.cpp. And so on.
Essentially, this was a problem I could have solved by looking at the Simple Robot Template, a beginner's mistake.
