Go to Post Ice cream is an iterative process. - JVN [more]
Unread 02-02-2013, 13:24
MI6 MI6 is offline
FRC #4362
Rookie Year: 2011
MI6 is an unknown quantity at this point
C++ Tank Drive Help
Please help with the errors and how to use a xbox controller with it!
I am getting a few errors with my code!
- Error: expected identifier before numeric constant
- Error: ISO C++ forbids declarations of parameter with no type
- Error: expected ',' or '...' before numeric constant
-Syntax Error
Code:
#include "WPILib.h"
class RobotDemo : public SimpleRobot
RobotDrive drivetrain(1, 2);
Joystick leftStick(1);
Joystick rightStick(2);
public:
RobotDemo()
GetWatchdog().SetEnabled(false);
void Autonomous()
void OperatorControl()
while (1) // loop forever
drive.Tank(leftStick, rightStick); // drive with the joysticks
Wait(0.005);
START_ROBOT_CLASS(RobotDemo);
Unread 02-02-2013, 16:34
Domenic Rodriguez's Avatar
Domenic Rodriguez Domenic Rodriguez is offline
FRC #0316 (LuNaTeCs)
Rookie Year: 2011
Domenic Rodriguez has a spectacular aura aboutDomenic Rodriguez has a spectacular aura aboutDomenic Rodriguez has a spectacular aura about
Re: C++ Tank Drive Help
In C++, you can't initialize non-const member variables at declaration. They need to initialized in the constructor. An easy way to do this is to use C++ initialization lists (more info on which can be found here).
Instead of writing your code like this:
Code:
public:
RobotDemo()
It would look more like this:
Code:
RobotDrive drivetrain;
Joystick leftStick;
Joystick rightStick;
public:
RobotDemo() : drivetrain(1, 2), leftStick(1), rightStick(2)
Instead of initializing the variables when they are declared, we initialize them in a list after the name of the constructor. This should solve the compiler errors.
Also, if you want to access the second joystick on the XBox controller, you need to use the GetRawAxis() function instead of declaring a second joystick. This also means that you have to pass the values of the two axes to the TankDrive function instead of the joystick object. The button and joystick mappings for the XBox controller can be found in this post, but I'll copy the relevant portion below:
  • 1: Left Stick X Axis
    -Left:Negative ; Right: Positive
  • 2: Left Stick Y Axis
    -Up: Negative ; Down: Positive
  • 3: Triggers
    -Left: Positive ; Right: Negative
  • 4: Right Stick X Axis
    -Left: Negative ; Right: Positive
  • 5: Right Stick Y Axis
  • 6: Directional Pad (Not recommended, buggy)
For this example, if we wanted to have the XBox left Y axis control the left side of the tank drive and the right Y axis control the right side, it would look like this:
Code:
drivetrain.TankDrive(joystick.GetY(), joystick.GetRawAxis(5);
Here's the whole file for reference
Code:
#include "WPILib.h"
class DemoRobot : public SimpleRobot
	Joystick xbox;
public:
	DemoRobot() :
		drivetrain(1, 2), xbox(1)
	void Autonomous() {}
		while (IsOperatorControl()) {
			drivetrain.TankDrive(xbox.GetY(), xbox.GetRawAxis(5));
			Wait(0.005);
START_ROBOT_CLASS(DemoRobot);
Hope this helps. If you have any more questions, feel free to ask
- Domenic
Unread 02-02-2013, 21:41
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Typically a compiler error message is accompanied by the line on which the error was detected. In C/C++, that is sometimes the line after the one with the actual problem. What line is identified as causing each of the errors you see?
You're defining your RobotDrive object as "drivetrain" but you're trying to call the Tank method of something called "drive". I don't know that it's the cause of your compile errors, but it looks suspicious to me.
Unread 03-02-2013, 03:03
bob.wolff68's Avatar
bob.wolff68 bob.wolff68 is offline
Da' Mentor Man
FRC #1967
Rookie Year: 2007
bob.wolff68 is just really nicebob.wolff68 is just really nicebob.wolff68 is just really nicebob.wolff68 is just really nicebob.wolff68 is just really nice
It is also unlikely that you mean what is stated regarding leftstick and rightstick. What is in the code says that joystick controller #1 (the first xbox controller) will be the left-stick while the right part of the tank drive will be controlled by joystick #2 (the 2nd xbox controller). What you more likely want to do is use particular parts of a single joystick - a particular axis of joystick #1 for the left and a particular part/axis of joystick #1 for the right.
One of my students (holly4win) posted in a separate thread today about a "joystick investigator" program our team wrote which you might find useful to getting this information - see the thread at http://www.chiefdelphi.com/forums/sh...d.php?t=103156
Thanks,
bob
Bob Wolff - Software from the old-school
Mentor / C / C++ guy
Team 1967 - The Janksters - San Jose, CA
