Go to Post Bomb squad, that grabber was the coolest way to grab a tetrahedral object in the history of grabbing tetrahedral objects. - IronVulture [more]
Unread 02-02-2013, 02:48 PM
Gmercer Gmercer is offline
None #1631
Gmercer is an unknown quantity at this point
Programming an arcade drive for joysicks
I'm having a lot of trouble coming up with an algorithm on programming an arcade drive on a single joysick. We're using one joystick for our shooter, so our other one must drive the entire robot, here is what i know:
For both(joysticks):
Y values:
Up is -1
Down is 1
X values:
Left is -1
Right is 1
i know there is something to do with triangles, but i'm not quite sure. Any help / links are really appreciated, thanks!
Unread 02-02-2013, 02:55 PM
Ether's Avatar
Ether Ether is offline
systems engineer (retired)
Rookie Year: 1969
Re: Programming an arcade drive for joysicks
Y values:
Up is -1
Down is 1
X values:
Left is -1
Right is 1
You don't need to invent your own algorithm (unless you want to).
The Java WPILib already has a ready-made Arcade Drive object.
It's in the file "RobotDrive.java"
Unread 02-02-2013, 03:07 PM
None #1631
Thank you very much! do you know where i can find an example of this class in action? i seems a bit confusing to me, i'm not sure where to place the robotDrive code(in a move function or when initialized?).
Unread 02-02-2013, 03:30 PM
Ether's Avatar
Rookie Year: 1969
Doesn't your FRC Java installation come with a complete example project, complete with drive code, which shows where everything goes?
Unread 02-02-2013, 03:36 PM
None #1631
It includes a sample project on how to pick up reflective tape and aim, but nothing on the arcadeDrive object
EDIT: got it working! thanks for the help, though i came across another problem when i got the arcade drive working....
I had to remove my calls to the jaguars to initialize the arcade drive object, so i need to also modify my shoot function. it WAS like this:
Code:
if(gShoot.getAngle < finalAngle) {
    //slowly turns motors until angle is reached
    jag1.set(.15);
    jag2.set(.15);
    jag3.set(.15);
    jag4.set(.15);
i tried using arcadeDrive(0.0, .15) but the robot just stood still, should i use the drive functin instead?
//function goes on...
Unread 02-02-2013, 05:46 PM
Arhowk's Avatar
Arhowk Arhowk is offline
FiM CSA
AKA: Jake Niman
FRC #1684 (The Chimeras) (5460 Mentor)
Rookie Year: 2013
Arhowk is a splendid one to beholdArhowk is a splendid one to beholdArhowk is a splendid one to beholdArhowk is a splendid one to beholdArhowk is a splendid one to beholdArhowk is a splendid one to behold
Code:
    jag1.set(.15);
    jag2.set(.15);
    jag3.set(.15);
    jag4.set(.15);
use
arcadeDrive(0,0.15)
though 0.15 is hardly ANYTHING, i cant get my robot to move (due to jaguars not putting enough force) without a 0.25 move
