pic: 2175 Wheel
Re: pic: 2175 Wheel
That 3D printed?
Re: pic: 2175 Wheel
Not sure, looks fairly smooth/can't see any layers, but that might just be the picture. |
Re: pic: 2175 Wheel
It IS 3D printed!
Re: pic: 2175 Wheel
ABS-M30, to be exact. If you zoom waaay in you can kinda see the layers.
Re: pic: 2175 Wheel
That's pretty sweet. Do you guys have the printer in-house? If so, which make/model is it?
Re: pic: 2175 Wheel
we have a printer in shop but these were made on a statasys printer by a sponsor, with a stronger material and larger build space then our in house printer. If we made them in house we'd have to make them one at a time instead of our sponsor making them four at a time.
Re: pic: 2175 Wheel
Edit: beaten to the punch. Also, I should give a shout out to 207, where we got the inspiration for this. We wanted a one piece, no hardware, direct driven wheel, but all our options were very expensive or required a lot of machining time ... this has so far turned out to be a perfect alternative. Last edited by Aren Siekmeier : 02-02-2013 at 17:03. |
Re: pic: 2175 Wheel
i highly recommend testing them and abusing them before competition. We have 4 stratus machines and 2 fortus machines at work and we only use them for prototyping purposes... Im a bit skeptical that those will hold up. my $0.02
#10
Re: pic: 2175 Wheel
Depending what your work does, I can understand the prototyping. It can be quicker than machining or casting, but for the long runs of parts you'd want to look a lot harder at other methods to see if they'd work. For small batches or a quick turnaround, though... |
#11
Re: pic: 2175 Wheel
One of the other members has just informed me that the wheel hub held at 45 foot-pounds of torque, and failed at 60 foot-pounds, in our rather unscientific torque-wrench tests. Our strategy this year does not involve 30-point climbs, so we are not as concerned about our wheels surviving a long drop. |
#12
Re: pic: 2175 Wheel
I'm glad to see others picking up 3D printed wheels as well. I've put these pictures in other threads before, but I'll put them here again.
Here's a picture of our 2011 and 2012 wheels side by side. This is a fairly good example of what we expect our wheels to endure. We've driven those same sets of wheels quite a few times on concrete/hard floors since, without any damage as of yet. And to the OP; your wheels look fantastic, and I'm sure they'll work great. If you choose to continue using 3D printed wheels, I'd change some of those sharp corners to radii, it'll strengthen them a bit. I personally hope we end up on the same field together at some point ![]() Also, here's a sneak peek of what we've got for 2013. Last edited by Botwoon : 02-02-2013 at 21:47. |
