Go to Post Let's see some love for these fine people. Let's give it up for the refs. - Andy Baker [more]
Unread 03-02-2013, 04:02
Garret's Avatar
Garret Garret is offline
Standing on the Shoulders of Giants
AKA: Garret Smalley
FRC #0691 (Hart District Robotics)
Garret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond repute
pic: Team 691 2013 Frame
Unread 03-02-2013, 04:04
Mr. Lim Mr. Lim is offline
AKA: Mr. Lim
Team Role: Leadership
Rookie Year: 1998
Mr. Lim has a reputation beyond reputeMr. Lim has a reputation beyond reputeMr. Lim has a reputation beyond reputeMr. Lim has a reputation beyond reputeMr. Lim has a reputation beyond reputeMr. Lim has a reputation beyond reputeMr. Lim has a reputation beyond reputeMr. Lim has a reputation beyond reputeMr. Lim has a reputation beyond reputeMr. Lim has a reputation beyond reputeMr. Lim has a reputation beyond repute
Re: pic: Team 691 2013 Frame
Very neat suspension setup! A lot of people who do mecanum don't realize just how important keeping all 4 wheels on the ground is...
Great work!
In life, what you give, you keep. What you fail to give, you lose forever...
Unread 03-02-2013, 05:44
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
Rookie Year: 1999
I was thinking the same thing.
I wonder how effective it is? Does it have nice spring and damping characteristics, or do you find that the robot bounces around too much, or not enough?
Care to share any design parameters that you've calculated—especially the specs of any springs or dampers used?
Unread 03-02-2013, 10:47
Nick Lawrence's Avatar
Nick Lawrence Nick Lawrence is offline
Commander Canada
FRC #3940 (CyberTooth, AndyMark)
Nick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond repute
Gorgeous suspension setup. I wonder if you guys are having any binding issues with it though?
-Nick
Alumnus of 1503 Spartonics
Founding Mentor of 5406 Celt-X
Mechanical Design Mentor of 3940 CyberTooth
Emceeing events since 2013 - come say hi!
Success doesn't always equate to match wins. It's about the wins off the field.
Unread 03-02-2013, 15:28
Kevin Ray's Avatar
Kevin Ray Kevin Ray is offline
None #0329 (Raiders)
Rookie Year: 2000
Kevin Ray is a splendid one to beholdKevin Ray is a splendid one to beholdKevin Ray is a splendid one to beholdKevin Ray is a splendid one to beholdKevin Ray is a splendid one to beholdKevin Ray is a splendid one to beholdKevin Ray is a splendid one to beholdKevin Ray is a splendid one to behold
-Nick
It's hard to tell from the photo but I'll bet that either bronze or nylon sleeves surrounding the bolts below the springs would work to alleviate any binding issues.
No matter what, that's a very nice design for macanums. I especially like that fact that it looks like a breeze to replace any part on the whole drive system.
_____________________________________________
Last words before magic smoke appears: "There, that oughta work!"
2016 Utah Regional- Engineering Inspiration
2016 Utah Regional- Dean's List Semi-Finalist- Ed O'Connor
2016 Utah Regional- Dean's List Semi-Finalist- Emily Ferrari
2016 Utah Regional- 3rd seed
2016 SBPLI Regional- Finalist, 6th seed
2016 SBPLI Regional- Gracious Professionalism Award
Unread 03-02-2013, 17:33
Garret's Avatar
AKA: Garret Smalley
Thank you all for the kind words, we are very happy with how this drive has turned out this year.
The suspension on this years robot primarily serves to ensure that all wheels are on the ground, because of that we really weren't too worried about having noticeable travel on the suspension. When driving the robot there is no noticeable bounce as far as we can tell.
We used the same springs in 2011 that we are now (McMaster PN: 9657K255). According to the specs listed the springs have a max load of 21lbs each. With 4 springs per module that would mean a max of 80lbs per module. That's a very high number but realistically you are more likely looking at around 40lbs per module which puts the springs at half compression, this is what you want for any suspension because it allows it to move both up and down to compensate for a non-level playing surface. In reality that's about all the math I ever do when I am looking at our suspension springs (that's all that is needed), to us the suspension is basically just an assumed part of the robot, we have done it on regular skid steer drive trains, swerve, and mecanum.
We had bronze bushings in the drive last year, however we removed them at the tournament because they really weren't necessary (as long as you use partially threaded bolts and slightly oversize holes). With this type of module it is easy to add bronze bushings or sleeve bearings if deemed necessary (only requires the holes to be enlarged). The idea behind the suspension is literally a "poor man's" solution to mecanum drive (or any drive that benefits from all wheels on the ground) with a stiff frame. When we first did this in 2011 it was done as a replacement to using shims to fix "bad pillow blocks" so that the drive would sit right.
So far we are quite literally amazed by the performance of this drive so far, especially the Vexpro mecanum wheels. We are getting surprisingly large pushing force right now with the base shown we were getting around 60+ lbs of pushing force (I don't have a weight on the robot right now but it is considerably less than 60 lbs. I am happy to answer any other questions about the drivetrain and suspension system.
7 Years of FRC
"You students are at the top of the mountain, at the pinnacle of success, and what is it that you do?
You become the future guides to help others climb the mountain."
