Go to Post Honesty and Integrity is the key to success. - team4384 [more]
Unread 03-02-2013, 13:51
gitlitz gitlitz is offline
FRC #4590
gitlitz is an unknown quantity at this point
vision processing on laptop
hi all,
we are trying to run the vision process on our laptop on a laptop and send the results to the crio.
We found a vision lib at
Code:
C:\Program Files\SmartDashboard\extensions\lib
but we get an error while trying to execute our code.
Our error appears at the first line:
Code:
AxisCamera camera=AxisCamera.getInstance("10.45.90.11");
Our source code is:
Code:
import edu.wpi.first.wpilibj.camera.AxisCamera;
public class Main {
	public static void main(String[] args){
When executing the code we get the following error:
Code:
Exception in thread "main" java.lang.Error: Unresolved compilation problem:
	at edu.wpi.first.wpilibj.camera.AxisCamera.getInstance(AxisCamera.java:241)
	at Main.main(Main.java:13)
If you have a better idea on how to do the vision processing on the laptop you are more than welcome to post it here
Unread 03-02-2013, 15:42
inkspell4's Avatar
inkspell4 inkspell4 is offline
FRC #3650 (Robo Raptors)
Rookie Year: 2011
inkspell4 will become famous soon enough
Ive been trying to figure out how to process the vision on the laptop
Chesapeake Regional : 2013, 2012, 2011
Rookie Year: 2011
2013 RoboRaptors Team 3650 Programming Team Captain
Team Website : http://www.roboraptorsfrcteam3650.com/index.html
_____________________________________________
Unread 03-02-2013, 22:36
Ginto8's Avatar
Ginto8 Ginto8 is offline
Programming Lead
AKA: Joe Doyle
FRC #2729 (Storm)
Rookie Year: 2010
Ginto8 is a glorious beacon of lightGinto8 is a glorious beacon of lightGinto8 is a glorious beacon of lightGinto8 is a glorious beacon of lightGinto8 is a glorious beacon of light
Re: vision processing on laptop
You're having problems because you're trying to use the WPILib vision library (built on NIVision) on the laptop. Those libraries (to my knowledge) don't exist on the cRIO. To do image processing on the laptop, you'll want to make a SmartDashboard extension extending WPICameraExtension, using some combination of WPIJavaCV and OpenCV. Check out Miss Daisy's code from last year for some inspiration there.
I code stuff.
Unread 04-02-2013, 07:19
The NIVision libraries do exist on both cRIO and on Windows laptops. They are callable from C and LV and languages that can wrap C. The vision libraries are how the default dashboard does the display and the annotations.
Documentation for it is in Start>>All Programs>>National Instruments>>Vision>>Documentation. The C specific documents tend to have CVI somewhere in the name, and the Concepts manual is highly recommended.
Greg McKaskle
