Team 3313 Practice Run #2
Hello again CD community!
Video: http://www.youtube.com/watch?v=Pvq5otqt4mIhttp://www.youtube.com/watch?v=Pvq5otqt4mI FRC Team 3313 Mechatronics from Alexandria, MN did another practice run with our robot. We used the practice setting on the drive station. 2/2 on Autonomous, 9/12 during Teleop, and a 10 point hang. Obviously, there is no defense played here and the "field" we are playing on is about 8 ft. short of a normal one. But it's still good to practice! More improvements planned: fencing to protect the electronics, a topper on the hopper to prevent Frisbees from sticking, some kind of vision processing (photon cannon?), and a kick stand for setting up the robot to start. We also plan to make an autonomous from the back of the pyramid as well. Let us know any thoughts or comments!! We have always appreciated all the advice, compliments, and comments from the FRC community. Last edited by MrBydlon : 03-02-2013 at 23:06. |
Re: Team 3313 Practice Run #2
The third shot of teleop actually went under the goal, not into it. So, 9/12.
That looks fantastic! As always, make sure to test on carpet as well. Since you already have such an excellent robot, what are your plans for the next two weeks?
Nice bot
![]() You said above something about vision processing. How about instead of that, you put a structure on top of your shooter that allows you to back up into the pyramid and be aligned. This type of "hard stop" alignment tends to be infinitely faster and more reliable than vision tracking. |
Great job guys, this robot needs tweaking but is effectively done. Having 2 weeks to just straight practice and work out the kinks will be huge.
My advice: feel free to throw it in the trash but I really like your robot and would love to see it perform that much better. Your drive could be much faster, see if there is something small that you can do to make it better. I would stay away from changing your wheel size because that could hurt your very accurate shooting. Something like a different sprocket or pulley on your wheels or gearbox depending on what you use to gear it faster could give you another run to and from the hp station a match. With the motors you have and the fact that pushing doesn't seem to be that big of a deal you could go up to 13-14 feet per second as opposed to what looks like 8-9 feet per second. Why not change all your wheels to omni wheels? This will allow you to turn about the center of your robot instead of around basically the end of it, this will make your turning tighter and faster. Maybe take some of the time you have to try and have the robot begin to backup to the feeder at the end of your auton? This will cut into the time spent going to the feeder station at the start of teleop. |
I would also second someone comment about using the pyramid to align yourself. Remember, you can't be rammed or pushed if you are touching the pyramid (right?), so it somewhat functions as the key did last year. |
I like it, I think this "type" of robot will be very successful this year.
I would suggest that you work on an auto mode that shoots into the 3 point goal but from the side of the pyrimid. That free's you up during auto so if your other partners need to start in the dead center everyone can still score in the 3 point goal. Other then that I would just say practice, practice, practice. Regards, Bryan Last edited by BJC : 03-02-2013 at 22:37. |
You might also, next time, practice driving head on instead of from the side. I've tried both and, at least IMHO, there's a difference in perception.
#10
You look a lot like you might be able to score from hanging position. That would be really cool.
Also, I suggest you practice cutting down time in your loading sequence. Two things I have noticed that work well: 1. Slam into the feeder station and let your bumpers allow you to become flush to the wall. 2. Have your human player stack 4 frisbees and balence them on one hand. Then, use your other hand to "shuffle" the top frisbee through the slot. Feed continuously. Best of luck. Keep us posted. -Jeff |
#11
This robot looks great guys! I've got a suggestion, besides those that haven't already been mentioned, that I feel would benefit you guys greatly.
I complete agree with using your robot as a hard stop against the pyramid. One of the things you might want to try is adjusting the angle of you shooter, if it is at all possible, and trying to shoot from the back of the pyramid through it. that would greatly increase the speed at which you could collect Frisbees and shoot them, and it already looks like you have the distance to do it. The neon looks really cool too |
#12
Great work! A lot farther than most of the teams I've seen.
Have you guys practiced with a goal that has chain in it? I recommend doing so just to check if at your shooting angle and speed, frisbees aren't able to bounce back out. Good luck with this strong robot! |
#13
I wanted to echo Akash's chain comment above. The frisbees bounce out of the goals when they interact with the chains in strange ways... Seems to be more common with closer range shots with a lot of spin and velocity. With more than 2 weeks to tweak and practice, you guys will be in great shape!!! |
#14
With this much time left, have you thought about doing a 20 point lift and/or floor feeder addition? Looks like you have some room left.
#15
I'm with Glenn -- you may be able to do a floor feeder.
Whatever you do, to be competitive in the finals you'll have to push for 4-5 hoppers worth of discs. Keep practicing and get that timing down right! |
