Go to Post Curse you and your logic! - Koko Ed [more]
Unread 04-02-2013, 07:33
gowner gowner is offline
AKA: Fabian
FRC #2833 (Robo-Scorpions)
Team Role: Teacher
Rookie Year: 2007
gowner is an unknown quantity at this point
Aluminum parameters
Where can we find max/min aluminum thickness? We are kind off new and could not find even doing search. Thanks to all and good luck this year!
2833 Robo-Scorpions
Unread 04-02-2013, 08:30
DELurker DELurker is offline
Former Engineering Mentor
AKA: William Lydick
no team (n/a)
Rookie Year: 2011
DELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant future
Re: Aluminum parameters
As they are one of our team's sponsors, here is a link to the Ryerson stock list. You should be able to find any commercially available size in there.
http://www.ryerson.com/en/Products/Stock-List
Also, try www.mcmaster.com for materials.
Of course, what specifically are you looking for? Aluminum plate? Sheet? Foil? Within the 120 pound limit, there's only so much you can have...
With 1370 --
2012 Rutgers District Event Champions with 1676/56
2012 Lenape District Event Finalists with 2191/1691
2013 TCNJ District Event QuarterFinalists with 1143/4750, Gracious Professionalism Award
2013 Bridgewater-Raritan District Event Semi-Finalists with 4285/223
2013 MAR Championship Finalists (Backup) with 222/11/1403; Gracious Professionalism Award
Unread 04-02-2013, 09:58
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
2833 Robo-Scorpions
If you are talking under the rules of robot construction there are no min or max thickness requirements. Us whatever you need. from a piece of aluminum foil to a block that would be the max size of the robot.
Unread 04-02-2013, 10:15
Richard Wallace's Avatar
Richard Wallace Richard Wallace is online now
I live for the details.
FRC #3620 (Average Joes)
Rookie Year: 1996
Originally Posted by IndySam View Post
... a block that would be the max size of the robot.
assuming a rectangular block 60 inches tall with 112 inch perimeter, you might run into the weight limit. 60 x 26 x 30 / 10 = 4680 lb.
If you start with said block, you will end up converting more that 97.5% of it into chips, to leave less than 120 lb. for the finished robot. That's a lot more chips than a sculptor generally creates -- think of Michaelangelo beginning with a large block of marble, and chipping away everything that is not David.
Richard Wallace
since 2003
Unread 04-02-2013, 10:20
IndySam's Avatar
And then there is the cost of said block, probably a little more than $400. I wonder if you could use the money from recycling those chips to lower the overall cost?
