Go to Post I remember as a kid thinking how high a team number like 834 was. - Dancin103 [more]
Unread 04-02-2013, 17:50
James H James H is offline
FRC #4256
James H is an unknown quantity at this point
2 Joysticks Needed?
This is our second year of FRC, so here's a little background info on what we've done so you guys can pick out if this is our fault or Labview's:
Last year we had 2 joysticks working great with no conflicts
This year we've had 1 joystick working great without conflict
When I set up a second joystick in Begin.vi, we started having problems. The joystick input for the motors got messed up when we only had one of the two joysticks plugged into the laptop. We messed around with our code for a while, but the only solution we found is plugging in the second joystick.
We're using Logitech Attack 3 Joysticks. The TeleOp code is attached
So if this is our fault, anyone have any ideas? If its not, I guess this is just reporting an issue.
Thanks,
Team 4256
Unread 04-02-2013, 20:33
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Re: 2 Joysticks Needed?
Can you give a little more information about the problem? What are you expecting to happen, and what is happening instead?
Unread 04-02-2013, 20:45
FRC #4256
Basically what happened is this:
I tried to run the code on our robot with only 1 joystick plugged into the computer when in Begin.vi we have 2 joysticks set up. When I enabled TeleOp, the input of the joystick was skewed on the x-axis input to about 0.32 when the joystick was centered (where the values should be 0 and 0). When we plugged in the other joystick (so now both joysticks are plugged in) it returns to normal values when at rest. As far as I can tell, it's not an issue with our code and since we are planning to use 2 joysticks shouldn't be a big problem. However, I am wondering if it is an issue we can fix or if anyone else has encountered this.
Unread 04-02-2013, 22:59
Software Architect
Is the joystick x axis being nonzero when centered a repeatable phenomenon?
I suspect your joystick was off-center when it was first plugged in. It would have "calibrated" to that point, so it would have been offset from zero. Adding the second joystick could have recalibrated it when the Driver Station rescanned the USB devices.
Unread 04-02-2013, 23:27
FRC #4256
Nope, tried that. Tried replugging it in, switching joysticks, restarting the driver station, and even calibrating with joy.cpl. It was only fixed once we plugged in the second joystick.
