No battery voltage readings on DS!
We've tried to replace the analog breakout board on the cRio, and the jumper is hooked up to the two outer pins. Still no battery voltage readings on the DS. Does anyone know what's wrong?
Re: No battery voltage readings on DS!
Is the green power light on the Analog Breakout board itself brightly lit?
Do you have power from the Power Distribution Panel wired directly into it? |
Yes, The green light is brightly lit and I believe it's also powered from the power distribution board.
Is the Analog Module labeled NI 9201?
Is the Module in the first cRIO slot? |
Yes, and Yes.
Pull the Analog Module out of the chassis and visually inspect the pins in the bottom of the chassis. Look for metal debris or bent pins.
We did, and everything seems fine.
8-slot or 4-slot cRIO?
8-slot
#10
The 8-slot's collect metal dust and debris inside.
If it's a used one, have you cleaned out the case lately? It should be cleaned each year before being mounted on a new robot. It does weird things when there is dust inside, so that might be a possible cause. I assume nothing else is plugged into the Analog ports that might cause a short. You can test the Breakout with a multimeter to see the battery voltage on the pins you put the jumper on. Measure from the pin to any ground. Use the multimeter to verify continuity through the jumper in case it isn't really a jumper. (I only say that because I once found a team using a cable connector instead-it didn't work.) Last edited by Mark McLeod : 04-02-2013 at 22:54. |
#11
I will check on it tomorrow. I appreciate your help.
#12
Was a solution to this problem found?
