Go to Post No disclaimer on earth lets you disassociate yourself with your team or what you represent because you want to say something not particularly nice, but lets you be associated again when you want to say something to encourage others, etc. - Amanda Morrison [more]
Unread 04-02-2013, 22:09
team3039 team3039 is offline
FRC #3039
team3039 is an unknown quantity at this point
No battery voltage readings on DS!
We've tried to replace the analog breakout board on the cRio, and the jumper is hooked up to the two outer pins. Still no battery voltage readings on the DS. Does anyone know what's wrong?
Unread 04-02-2013, 22:17
Mark McLeod's Avatar
Just Itinerant
AKA: Hey dad...Father...MARK
FRC #0358 (Robotic Eagles)
Re: No battery voltage readings on DS!
Is the green power light on the Analog Breakout board itself brightly lit?
Do you have power from the Power Distribution Panel wired directly into it?
Unread 04-02-2013, 22:19
FRC #3039
Yes, The green light is brightly lit and I believe it's also powered from the power distribution board.
Unread 04-02-2013, 22:23
Just Itinerant
Is the Analog Module labeled NI 9201?
Is the Module in the first cRIO slot?
Unread 04-02-2013, 22:25
FRC #3039
Yes, and Yes.
Unread 04-02-2013, 22:28
Just Itinerant
Pull the Analog Module out of the chassis and visually inspect the pins in the bottom of the chassis. Look for metal debris or bent pins.
Unread 04-02-2013, 22:31
FRC #3039
We did, and everything seems fine.
Unread 04-02-2013, 22:36
Just Itinerant
8-slot or 4-slot cRIO?
Unread 04-02-2013, 22:39
FRC #3039
8-slot
Unread 04-02-2013, 22:50
Just Itinerant
The 8-slot's collect metal dust and debris inside.
If it's a used one, have you cleaned out the case lately?
It should be cleaned each year before being mounted on a new robot.
It does weird things when there is dust inside, so that might be a possible cause.
I assume nothing else is plugged into the Analog ports that might cause a short.
You can test the Breakout with a multimeter to see the battery voltage on the pins you put the jumper on. Measure from the pin to any ground.
Use the multimeter to verify continuity through the jumper in case it isn't really a jumper. (I only say that because I once found a team using a cable connector instead-it didn't work.)
Unread 04-02-2013, 22:51
FRC #3039
I will check on it tomorrow. I appreciate your help.
Unread 05-02-2013, 21:43
inkspell4's Avatar
inkspell4 inkspell4 is offline
FRC #3650 (Robo Raptors)
Rookie Year: 2011
inkspell4 will become famous soon enough
Was a solution to this problem found?
Chesapeake Regional : 2013, 2012, 2011
Rookie Year: 2011
2013 RoboRaptors Team 3650 Programming Team Captain
Team Website : http://www.roboraptorsfrcteam3650.com/index.html
_____________________________________________
