Go to Post Got Valentine's day present from wife before leaving for work. Non-contact IR thermometer, two unscuffed pairs of safety glasses for competitions, bag of York peppermint patties. She understands me. - Greg Young [more]
Unread 04-02-2013, 22:28
Grim Tuesday's Avatar
Grim Tuesday Grim Tuesday is offline
AKA: Simon Bohn
FRC #0639 (Code Red)
Rookie Year: 2010
Grim Tuesday has a reputation beyond reputeGrim Tuesday has a reputation beyond reputeGrim Tuesday has a reputation beyond reputeGrim Tuesday has a reputation beyond reputeGrim Tuesday has a reputation beyond reputeGrim Tuesday has a reputation beyond reputeGrim Tuesday has a reputation beyond reputeGrim Tuesday has a reputation beyond reputeGrim Tuesday has a reputation beyond reputeGrim Tuesday has a reputation beyond reputeGrim Tuesday has a reputation beyond repute
Indexing
We finished the final version of our shooter today and noticed a problem we had not observed in our prototypes: As our CAM running on a VEX 393 comes around the back to push them out, it seems like the discs were bound together and stuck on the front wall of our hopper. We investigated and it appears that as we threw them in at a 30 degree angle to mimic the feeder station, the discs were stacking at weird angles and getting caught up in eachother.
I remember earlier this season seeing a team use little plastic spurs to separate discs and nullify this problem. However, right now I can't seem to pinpoint the thread. I'd be much obliged if someone could point me in the right direction.
What are some ways you guys have found to keep the discs from getting misaligned and binding together?
Unread 04-02-2013, 22:55
lcoreyl's Avatar
lcoreyl lcoreyl is offline
WittyTitleGen can't link to library
AKA: Milner
lcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud of
Smile Re: Indexing
I remember the video you're referring to, and i think those spurs would help if the weight of the stack of discs was the problem, but it sounds like your problem is the angle the discs enter. Have you tried loading one at a time vs a bunch at a time? If you can repeatedly load one disc successfully then try loading 4 at a time but slow enough for each disc to settle before the next one enters.
And as always--pictures are worth a thousand words... My advice is based on a LOT of assumptions here
Unread 14-02-2013, 12:25
silverD's Avatar
silverD silverD is online now
Build Mentor
AKA: Nate
FRC #2052 (KnightKrawler)
Rookie Year: 2007
silverD is a splendid one to beholdsilverD is a splendid one to beholdsilverD is a splendid one to beholdsilverD is a splendid one to beholdsilverD is a splendid one to beholdsilverD is a splendid one to beholdsilverD is a splendid one to beholdsilverD is a splendid one to behold
Re: Indexing
I think this is what you are referring to
post #9
Unread 14-02-2013, 12:46
billbo911's Avatar
billbo911 billbo911 is offline
I prefer you give a perfect effort.
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
billbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond repute
Re: Indexing
We refer to this as a "nesting" problem. Maybe that's because we always seem to have "bird" theme, we are EagleForce after all.
What we use as an "anti-nesting" device is simply a screw that we adjust to allow one disk to fall in place, ready to shoot, but will not allow a second disk to drop until the first has been cleared out. It's basically a geometry issue.
CalGames 2009 Autonomous Champion Award winner
Sacramento 2010 Creativity in Design winner, Sacramento 2010 Quarter finalist
2011 Sacramento Finalist, 2011 Madtown Engineering Inspiration Award.
2012 Sacramento Semi-Finals, 2012 Sacramento Innovation in Control Award, 2012 SVR Judges Award.
2012 CalGames Autonomous Challenge Award winner ($$$).
2014 2X Rockwell Automation: Innovation in Control Award (CVR and SAC). Curie Division Gracious Professionalism Award.
2014 Capital City Classic Winner AND Runner Up. Madtown Throwdown: Runner up.
2015 Innovation in Control Award, Sacramento.
2016 Chezy Champs Finalist, 2016 MTTD Finalist
Unread 14-02-2013, 13:06
DMike
Posts: n/a
Re: Indexing
We have a similar issue. The second disc in the hopper would slide over the front of the bottom disc, creating a jam up in the exit slot. Our hopper is rolled .080 Aluminum with an outside diameter of 11.50 in. We placed some duct tape at the rear bottom going slightly up the rear hopper wall. Bascically smoothing out the corner between vertical hopper wall and bottom. This causes the bottom frisbee to slightly push forward through the exit slot. This in turn allows the rest of the stack to follow the same path and shoot freely ( for us anyway) . The duct tape seems like a weak fix, but it works and we may keep it.
Unread 14-02-2013, 13:34
Ty Tremblay's Avatar
Ty Tremblay Ty Tremblay is offline
Robotics Engineer
FRC #0319 (Big Bad Bob)
Ty Tremblay has a reputation beyond reputeTy Tremblay has a reputation beyond reputeTy Tremblay has a reputation beyond reputeTy Tremblay has a reputation beyond reputeTy Tremblay has a reputation beyond reputeTy Tremblay has a reputation beyond reputeTy Tremblay has a reputation beyond reputeTy Tremblay has a reputation beyond reputeTy Tremblay has a reputation beyond reputeTy Tremblay has a reputation beyond reputeTy Tremblay has a reputation beyond repute
Re: Indexing
Here's 319's indexing solution.
