Plaction wheel shooter?
Hello,
My team is a bit behind schedule, and we have not finished our shooter yet. We meant to use 8" AM pneumatic wheels directly driven from cim motors, but that caused very strong vibrations, which we didn't like. We tested the same setup with 8" AM Plaction wheels and the vibration was considerably lower. We would like to use the plaction wheels, but I'm afraid that they won't work as well as pneumatic wheels, and we won't be able to test for a few more days. So... has anyone seen, used, tested or heard of an 8" plaction wheel shooter? I'd like to try and gain some 2nd hand experience here in order to make the better decision early on. Thanks, -Leav |
Re: Plaction wheel shooter?
We are running 6" performance wheels from am and are having good results with it (not half court shots, but we can score reliably). I'd assume that you'd see similar results with 8'' plactions.
we used an 8 in plaction in our first round shooter test and it worked really well. we could make shoots consistently from the sides of the pyramid and behind it.
We are using 8" FIRST rubber wheels with added on belting, and these work great. It was not much different than the pneumatic wheels as far as distance goes. We also mount them low on the frisbee.
Alex,
What belting are you using, and how did you mount it to the wheel? We might want to do something similar, but I'm wondering about the safety issues that others have mentioned (tread tearing off at high speed). What is the highest RPM you have tested with this belting? |
just make sure the plaction tread is on correctly if not the tread can fly off and hit you like it happened to me and leave a nice mark
#10
Luke,
Did you find a way to install the plaction tread "correctly"? Code:
Correct == Safe && Effective |
#11
We're using AndyMark's pneumatic wheel and found it works well without the innertube and it doesn't require balancing.
#12
We're using 8" plactions and are doing quite well with them. Our controls group has been using our prototype to gather some data as we haven't received our machined shooter parts yet. We've been shooting pretty accurately and distance wise, they're good.
#13
We are using a 6" performance wheel with the wedgetop tread and its pretty good. we can shoot half court reliably. also we riveted the tread on. there's no vibrations, and its super quiet.
#14
We made a prototype shooter using an 8 inch plaction wheel a few weeks ago.
We have slow-mo video available here: http://www.youtube.com/user/EagleFor.../videos?view=0 We have changed our shooter design, but the plaction wheel worked fairly well. |
#15
We use the wedgetop from AndyMark (as it's already cut into a straight 1" strip) and drill and rivet to the wheel over a 3" interval. We normally use these on our drivetrain. We are currently spinning them at roughly 4000 rpm, without any separation. |
