Go to Post ... Imagine NOT being able to count on certain things to stay the same from year to year... It makes you wonder what sort of sick, twisted mind would do such a thing to all those innocent teams out there... - dlavery [more]
Unread 05-02-2013, 15:13
celticsfan645 celticsfan645 is offline
FRC #1474
celticsfan645 is an unknown quantity at this point
Unable to Get CRIO to Work
For the past week, my team has been having considerable trouble trying to get the CRIO to work. The problem has progressively gotten worse, as at first we simply could not make the driver station get the code, later on, the code would not deploy. It was at this point one of our mentors from FIRST came to help us. We checked to make sure the IPs were all correct, we re-imaged the CRIO, and we switched Ethernet cords to make sure a malfunctioning cord was not the problem, but we were unable to make any headway. As of now, the computer will not even connect to the CRIO, and frankly, I am at a loss for what to do. If anyone here could offer any advice on what to do, it would be greatly appreciated.
Unread 05-02-2013, 15:17
Hugh Meyer's Avatar
Hugh Meyer Hugh Meyer is offline
FRC #1741 (Red Alert Robotics)
Hugh Meyer has much to be proud ofHugh Meyer has much to be proud ofHugh Meyer has much to be proud ofHugh Meyer has much to be proud ofHugh Meyer has much to be proud ofHugh Meyer has much to be proud ofHugh Meyer has much to be proud ofHugh Meyer has much to be proud of
Re: Unable to Get CRIO to Work
Check that all firewalls and virus scanners are turned off and all ports are open.
-Hugh
Unread 05-02-2013, 15:28
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
How's your battery?
Unread 05-02-2013, 15:31
FRC #1474
We checked the battery with our voltmeter, and it was giving off about 10 volts. I am fairly certain that is enough power, but switching to a fully charged battery is probably worth trying.
Unread 05-02-2013, 15:49
MamaSpoldi's Avatar
MamaSpoldi MamaSpoldi is offline
Programming Mentor
AKA: Laura Spoldi
FRC #0230 (Gaelhawks)
Rookie Year: 2007
MamaSpoldi has a brilliant futureMamaSpoldi has a brilliant futureMamaSpoldi has a brilliant futureMamaSpoldi has a brilliant futureMamaSpoldi has a brilliant futureMamaSpoldi has a brilliant futureMamaSpoldi has a brilliant futureMamaSpoldi has a brilliant futureMamaSpoldi has a brilliant futureMamaSpoldi has a brilliant futureMamaSpoldi has a brilliant future
A 10 volt battery is really marginal... I would definitely change the battery. But I would also suggest trying to program the cRIO by directly connecting to it (ie. ethernet cable connected between laptop and cRIO port, eliminating the wireless completely). If this works then you can take a closer look at the communications components in the chain.
Unread 05-02-2013, 16:07
FRC #1474
OK, I tried changing the battery, and it was connected directly to the CRIO to start with, and it still isn't working. I tried pressing the reset button to see if it would allow me to connect after, but nothing happened.
All advice already given is greatly appreciated.
Unread 05-02-2013, 16:12
MamaSpoldi's Avatar
Programming Mentor
AKA: Laura Spoldi
Rookie Year: 2007
So you were able to successfully re-image the cRIO but now are unable to deploy code to it? Is it a 4 or 8 slot cRIO? What language are you working in? Can you ping the cRIO IP address from a command prompt? Do you have the netconsole running? Does it display any messages when the cRIO is turned on?
Unread 05-02-2013, 16:20
FRC #1474
I used to be able to re-image the CRIO, but as of late yesterday, the imaging software stopped connecting to the CRIO. I am running an 8 slot CRIO with labview, and the command prompt is unable to ping the CRIO. And no, I do not have the netconsole running.
Unread 05-02-2013, 16:30
Hugh Meyer's Avatar
The battery should not be connected directly to the cRIO. It should be wired to the PDB. Please review the "Wiring the 2013 FRC Control System which can be found at this link.
http://wpilib.screenstepslive.com/s/...control-system
-Hugh
Unread 05-02-2013, 16:40
FRC #1474
Sorry, that post was very poorly worded. What I meant by that was that I put on a new battery, and that the computer was directly connected to the CRIO. The CRIO is not connected directly to the battery. I am sorry for any confusion that may have caused.
Unread 05-02-2013, 16:49
MamaSpoldi's Avatar
Programming Mentor
AKA: Laura Spoldi
Rookie Year: 2007
Unfortunately, I can't help with the LabView stuff. However, if the cRIO imaging software can't access the cRIO then it might help to reformat it in safe mode. This thread (http://www.chiefdelphi.com/forums/sh...d.php?t=111923) has lots of info on how to get the imaging back up and running. In particular suggestions related to turning off all wireless networking and firewalls on the PC (including clicking on the Advanced button in the IPV4 properties to make sure you have only one IP address set) and using the crossover ethernet cable to connect.
If you don't find the info that works there, it was suggested to contact National Instruments support at ni.com/frc.
Good Luck. I'll try to check back later.
Unread 06-02-2013, 10:45
MamaSpoldi's Avatar
Programming Mentor
AKA: Laura Spoldi
Rookie Year: 2007
Have you installed this update to the cRIO imaging tool?
http://joule.ni.com/nidu/cds/view/p/id/2262
According to the documentation it fixes a bug in it related to "Timeout error due to various network interface configurations".
Maybe it will help?
Unread 06-02-2013, 11:34
toastnbacon toastnbacon is offline
AKA: James
FRC #3169 (Saintborgs)
Rookie Year: 2010
toastnbacon is a jewel in the roughtoastnbacon is a jewel in the roughtoastnbacon is a jewel in the roughtoastnbacon is a jewel in the rough
Is the dashboard open on your computer? That caused us a lot of trouble earlier this year. I would try several different cables, just to be sure. And of course, don't forget to reset frequently!
"This must be what going insane feels like."-Simon Tam, Firefly
Unread 13-02-2013, 15:46
FRC #1474
Ok everyone, I managed to get the CRIO to work. What I did was I turned the IP Reset button on, rebooted the CRIO, turned the IP reset button off again, rebooted again, and then used the NI MAX to set an IP address. After that, I just had to re-image the CRIO. Thanks to all of you for your help.
