Go to Post Liberal arts majors learning more STEM concepts along with STEM majors learning more 'liberal arts' is a good idea. - ebarker [more]
Unread 05-02-2013, 21:03
clandry94 clandry94 is offline
AKA: Conor
FRC #3735 (KleinBOTS)
Team Role: Leadership
Rookie Year: 2011
clandry94 is an unknown quantity at this point
Location of the PD Board
Referring to rule 42
R42
The PD Board and all circuit breakers must be easily visible for Inspection
If we have the power distribution board underneath part of the robot that is able to be removed (sort of like a cover) does that fall under easily visible?
Unread 05-02-2013, 22:42
theawesome1730's Avatar
theawesome1730 theawesome1730 is offline
FRC #1730 (Team Driven)
Rookie Year: 2011
theawesome1730 will become famous soon enough
Re: Location of the PD Board
If the cover is held on with something like velcro or something similar I don't see a problem. You might even be able to get away with an easily un-boltable cover. I would make sure it is see through though. If any regional inspectors reply they can tell you what they would pass or reject.
2015 GKC Engineering Inspiration
2015 Colorado Winners
Unread 05-02-2013, 23:06
simpsonboy77 simpsonboy77 is offline
AKA: Garrett Dicken
FRC #0041 (RoboWarriors)
simpsonboy77 has a reputation beyond reputesimpsonboy77 has a reputation beyond reputesimpsonboy77 has a reputation beyond reputesimpsonboy77 has a reputation beyond reputesimpsonboy77 has a reputation beyond reputesimpsonboy77 has a reputation beyond reputesimpsonboy77 has a reputation beyond reputesimpsonboy77 has a reputation beyond reputesimpsonboy77 has a reputation beyond reputesimpsonboy77 has a reputation beyond reputesimpsonboy77 has a reputation beyond repute
From personal experience we have never had an issue with a clear cover over our breakers.
I think this rule exists so inspectors can look to make sure the amperage rating is correct for each motor.
2017 Shenzhen, China Regional CSA
2013 - Present MAR Control System Adviser and FTAA
2009 - Present Programming an Electrical Mentor Team 41
2007 - 2008 Team 41 Lead Programmer, Electrical
2005 - 2008 Team 41 Member
2008 NYC Regional Winner
Unread 06-02-2013, 01:09
Jaxom Jaxom is offline
AKA: Michael Hartwig
FRC #1986 (Team Titanium)
Jaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant future
Depends on your definition of "easy". I've inspected a number of robots with covers over parts of their innards; most have been no problem to inspect. Remember, YOU have to work on the robot if something goes wrong...if it's easy for you to work on the PD board it's probably easy for us to inspect.
We're looking for wire sizes and proper hookups (1 wire per Wago, radio and cRio power, etc.) along with amperages for motors and all of the other PD rules. I actually had to have one team turn their robot on its side to see the PD board; neither of us appreciated the extra time that inspection took.
Mentor http://www.teamtitanium.org/
Unread 08-02-2013, 22:29
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
All,
The rule exists so that inspectors can be sure you have the legal breakers installed, that the breaker meets the minimum wire size for the rating and that there is only wire in each WAGO terminal. We then check to see that the radio is wired correctly as is the Crio. During Power On testing we also check to see that all LEDs are lit. We will work with you if your design requires a special mounting, access or cover, but if you make impossible to see the above conditions you will have to correct it.
Al
WB9UVJ
www.wildstang.org
________________________
