Re: Issue with Talons
Could be related to new cable or not, just my observations. |
Both Al and Alan Andersons suggestions are good. The most likely problem is an intermittent PWM signal either at the software or hardware level.
Another possibility is an excessive periodic loop time. The time out on the Talon is 100 ms. That means if the Talon does not detect a rising OR falling edge after 100 mS, the output will be disabled. If you have access to an oscilloscope you may us it to verify your loop time by toggling a digital I/O every periodic loop. Make sure you call this in the same area you set the throttle value. As Alan stated the jump and jitter can be caused by an interrupted PWM signal. Check for poor PWM cabling and DSC performance issues. |
If your team doesn't have a scope and can't afford one, there's a fairly simple and inexpensive way I have used to create a piece of test equipment that will do things like this, using the RS232 or parallel port of an old laptop. If there's enough interest I will post a paper about it. PM me. |
http://www.ledametrix.com/oscope/index.html |
Food for thought: If all you are trying to do is measure the timing (not observe the waveform) of a digital signal then you don't need the sound card's ADC. All you want is to capture and timestamp the edges. The parallel port works great for this. You can poll the data pins of a parallel port at 680KHz or so... way beyond the frequency of the audio card. |
When we put our practice chassis together we had a "twitch" in our system too. We were not sending any commands to the DSC but the Talons signal light would blink and the motors would move for a brief moment. We switched to a different DSC and the problem went away. Opening up the DSC revealed that one of the chips had let out it's magic smoke. It was one that had been used in the past not a new unit, so it is hard to say when or why it occurred.
Our team have noticed random glitches from the drivetrain over the past few years, while no input was being sent, the drive motors would move just enough to make an audible noise, but not move the wheels.
We use Jaguars connected via PWM. **edit** Forgot to add, we are also using the round cable from the kop 2 years ago. Last edited by Nirvash : 06-02-2013 at 18:06. |
Try the code
I've had this same issue before but it was with the Jaguars. I ended up programming in the holonomic instead of arcade which seemed to solve it. It seems you may be having a similar issue best of luck and hope things go well.
Do you have two single acting solenoids available? Attach one to a solenoid breakout and the other to a relay. Turn them both on all the time. If both actuate when the talons reverse, the issue is that everything is getting disabled. If only the relay one is actuating, it points to a problem with the enable signal in the digital module or digital sidecar. If nether actuate, it's something specific to PWM signals.
#10
I would set those items aside for now and put them up on the bench for serious troubleshooting after ship date. Last edited by BitTwiddler : 07-02-2013 at 09:31. |
#11
Carl,
Is the twitching taking place when the robot is enabled or when you start to drive? Are you able to drive several minutes on one battery without the problem reoccurring? |
#12
To take Al's point further; Have you ruled out a power supply issue to the DSC?
If you are getting mixed results through swaptronics it is time to perform a more focused assessment of the problem. I would take a serious look at how the problem is reproduced, isolate the components instead of focusing on the system as a whole. Take a single motor controller and pair it with a DSC, PD and Cable on a bench off of the robot. Make every attempt to reproduce the issue. Paying very close attention to the steps being followed and what action cause the erroneous behavior. Once you are able to deterministic-ally reproduce the problem, then and only then will you be able to take the necessary steps to solving it. Having said that, if the problem is intermittent finding how to reproduce it can be very difficult. But it is still important to attempt to due so and avoid creation of causal relationships that may not have anything to do with the actual problem. Break the problem down to it's basic elements. From a hardware standpoint: What needs to happen for me to make a motor move? - Motor controller and DSC must have proper power. - Motor controller must receive a constant, uninterrupted(<100ms) PWM signal - Digital module on cRIO must be able to provide and uninterrupted non intermittent signal to the DSC. You must also be able to rule out specific components such as the motor controller itself. The easiest way to do this is provide the PWM signal to the Talon using a secondary form of communication such as a VEX controller or a simple PWM generator or an RC hobby controller. Once you have ruled out the MC, you need to move on to the other components such as the DSC. Testing the DSC is a little more difficult and requires you to know a little about how it works. But there is a simple test that you can do. If the problem is the DSC it is possible that it is only with one or two channels, try switching the PWM signal to a different channel. Remember that there is a separate driver IC for PWM channels 9 and 10 than there is for 1-8 http://www.usfirst.org/uploadedFiles...matic%20v7.pdf. Sometimes this IC fails or has intermittent issues that could be the cause of your problem. All of these tests requisite that you are able to reproduce the problem. If you cannot reproduce the problem then you have no way to validate your corrective measures. Now there is always the possibility that your problem is software. Try loading the default code and performing a simple PWM assignment from a joystick to a PWM channel. Try reproducing the issue on every channel. Compare these results against the actions taken to reproduce the problem. Following a methodical and step by step approach is the only way you are going to be able to pinpoint the problem and say with any reasonable degree of certainty that you have fixed it. |
#13
I don't have any issues with either the design or reliability of the DSC. It's just that it's such a swarf magnet. You really have to be careful working around them.
