Go to Post It’s possible to make friends without agreeing on everything. - Bill Gold [more]
Unread 06-02-2013, 08:00
Zach S. Zach S. is offline
FRC #3307 (Luray Robodawgs)
Rookie Year: 2011
Zach S. will become famous soon enough
Moving a motor a certain degrees?
Is it possible to move a motor one rotation without encoders? If so or if not how can I do it?
Head of Computer Systems and Programming of Team 3307
Unread 06-02-2013, 08:11
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Re: Moving a motor a certain degrees?
You don't need to use an encoder, but you do require some kind of feedback sensor to tell you when the motor has moved the desired amount. For a one-rotation action, a lever arm or cam and limit switch might work.
