Go to Post As an adult who has spent years working with youth in Boy Scouts and FIRST, and on behalf of all other adults at the event: deodorant. - Rick TYler [more]
Unread 02-06-2013, 11:32 AM
carterh062 carterh062 is offline
FRC #3929
carterh062 is an unknown quantity at this point
Exclamation Router/Camera/SmartDashboard issues.
Hi, I have seen a couple of other posts about this but none that were really resolved, and I was wondering if anyone had any answers. My team loves the smartdashboard, but this year we are encountering a bizarre error with it. Our camera will be plugged into our router and through a wired connection to the team computer, we can get the camera extension image perfectly from smart dashboard (Note that we are not using our own WPICameraExtension but actually the standard one that comes with smartdashboard). Unfortunately, when we try wireless, the connection is extremely spotty, and for the most part, the camera extension will say "no connection" on the smart dashboard.
However, and this is the weirdest part, through wireless, the computer is able to ping the robot as well as the camera, and we can see the camera in NI/FRC Dashboard as well as on the browser. Also, the driver station as well as smartdashboard have communications with the robot, and it can be enabled and disabled. We have verified that our camera ip is set correctly in smartdashboard, and our team number is correct. The only solution we have found is lowering the resolution in the axis camera settings to something less than 640x480 and the smartdashboard will pick the camera up wirelessly every time. It appears to be some sort of issue with sending too much information through the dashboard, but i'm not really sure. If anyone has had similar issues, or knows of a solution that doesn't mean losing information on the image, please let us know!
Thanks!
Carter,
Team 3929
